Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 09:28 PM   #1
car
thermostat
2 thermastats 2nd floor not working
car is offline   Reply With Quote
Old 10-06-2010, 09:30 PM   #2
car
I have 2 zone heating in my home second floor thermastat will not engage
Old 10-07-2010, 04:13 AM   #3
An old Tradesmen
Rewards Points: 8,144
What have you checked so far.
Old 10-07-2010, 05:20 AM   #4
car
I've changed the thermastat
Old 10-07-2010, 04:03 PM   #5
An old Tradesmen
Might want to check to see if the thermostat is getting any voltage. And then check to see if its sending voltage back tot he zone panel. And from there, if the zone motor is getting voltage.
Old 10-07-2010, 08:05 PM   #6
car
thermostat
i dont have any electricity going to 2nd zone thermostat
Old 10-07-2010, 08:18 PM   #7
HVAC / Plumbing
You will have to work back until you find where power is lost
kenmac is offline   Reply With Quote
Old 10-08-2010, 05:38 AM   #8
car
Where would i pick up a control box for furnace
Old 10-08-2010, 04:33 PM   #9
An old Tradesmen
The furnace, generally doesn't provide power to the thermostats in a zoned system.
Or do you have 2 furnaces?
Old 10-09-2010, 07:29 AM   #10
car
thermostat
No i dont have 2 furnaces but what i did was disconnected my leads to other box that seems to be controling my first floor and started up there is no power to the second floor thermostat
Old 10-09-2010, 07:35 AM   #11
If you don't have a volt meter it's going to be tough to troubleshoot. Pics would help a lot. If you have two thermostats and one furnace, that "control box" sounds a lot like a zone panel. It's a part completely independent of the furnace.
brandonmcginnis is offline   Reply With Quote
Old 10-09-2010, 09:05 AM   #12
car
thermastat
i did use my voltmeter and checked voltage to my second box which i believe controls my second zone mounted on side of furnace.
Old 10-09-2010, 10:33 AM   #13
An old Tradesmen
Take pics and post them.
So we know what these boxes look like.
Also, post brand and model numbers. So we know how they operate.
Old 10-09-2010, 12:19 PM   #14
car
thermostat
The boxes are Honeywell R8182 combination control
and the other i believe controling zone 2 is a American Stabilisthermostat-dsc00874.jpg
Old 10-09-2010, 05:09 PM   #15
An old Tradesmen
Ok.
You have a boiler, not a furnace.
Check the terminals of the circulator panel(the one on the side of your boiler) and see it you have voltage at the terminals that the thermostat wires to.
If not. Then check if you have 120 volts to the L1 and L2(hot and common) terminals of that same box.
If you have 120 volts going to it, but no voltage on the thermostat terminals. then the panels transformer is bad.
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
