-   -   thermostat (http://www.diychatroom.com/f17/thermostat-83246/)
car 10-06-2010 09:28 PM
thermostat
2 thermastats 2nd floor not working:furious:
car 10-06-2010 09:30 PM
I have 2 zone heating in my home second floor thermastat will not engage
beenthere 10-07-2010 04:13 AM
What have you checked so far.
car 10-07-2010 05:20 AM
I've changed the thermastat
beenthere 10-07-2010 04:03 PM
Might want to check to see if the thermostat is getting any voltage. And then check to see if its sending voltage back tot he zone panel. And from there, if the zone motor is getting voltage.
car 10-07-2010 08:05 PM
thermostat
i dont have any electricity going to 2nd zone thermostat
kenmac 10-07-2010 08:18 PM
You will have to work back until you find where power is lost
car 10-08-2010 05:38 AM
Where would i pick up a control box for furnace:(
beenthere 10-08-2010 04:33 PM
The furnace, generally doesn't provide power to the thermostats in a zoned system.
Or do you have 2 furnaces?
car 10-09-2010 07:29 AM
thermostat
No i dont have 2 furnaces but what i did was disconnected my leads to other box that seems to be controling my first floor and started up there is no power to the second floor thermostat:confused1:
brandonmcginnis 10-09-2010 07:35 AM
If you don't have a volt meter it's going to be tough to troubleshoot. Pics would help a lot. If you have two thermostats and one furnace, that "control box" sounds a lot like a zone panel. It's a part completely independent of the furnace.
car 10-09-2010 09:05 AM
thermastat
i did use my voltmeter and checked voltage to my second box which i believe controls my second zone mounted on side of furnace.
beenthere 10-09-2010 10:33 AM
Take pics and post them.
So we know what these boxes look like.
Also, post brand and model numbers. So we know how they operate.
car 10-09-2010 12:19 PM
thermostat
3 Attachment(s)
The boxes are Honeywell R8182 combination control
and the other i believe controling zone 2 is a American StabilisAttachment 25535
Attachment 25536
Attachment 25537
beenthere 10-09-2010 05:09 PM
Ok.
You have a boiler, not a furnace.
Check the terminals of the circulator panel(the one on the side of your boiler) and see it you have voltage at the terminals that the thermostat wires to.
If not. Then check if you have 120 volts to the L1 and L2(hot and common) terminals of that same box.
If you have 120 volts going to it, but no voltage on the thermostat terminals. then the panels transformer is bad.
