Old 11-11-2006, 07:44 PM   #1
Thermostat
We have a Honeywell Chromotherm III Model T8600A thermostat. Where the temperature should be there are instead the lettser "AC". The furnace won't come on. ANy advice will be appreciated.
wade52 is offline   Reply With Quote
Old 11-11-2006, 08:55 PM   #2
World famous jerk.
Thermostat
That means that your thermostat is not getting 24 volt ac power from the furnace, and is running off it's battery or capacitor only.
This can mean that your 24 volt fuse is blown in the furnace, the 24 volt transformer has failed, or the entire furnace does not have power for some reason.
mdshunk is offline   Reply With Quote
Old 11-11-2006, 08:56 PM   #3
Thoroughbred Mopar Man
Thermostat
Hi wade52
Pull the thermostat off the subbase, let it set on the table for about thirty minutes. Reinstall the thermostat and see if it works again. The Honeywell digitals are very sucebtible to static shock, if you touched thermostat with and static dicharged into it this will happen. Letting it bleed down removes the malfunction. If it does not work after bleeding it down you will have to replace it.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 03:36 PM
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 02:02 PM
Thermostat question ctown HVAC 7 12-05-2006 04:46 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
