Thermostat?? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2008, 10:34 AM   #1
Thermostat??
The other night we noticed the outside unit to the ac was not blowing, but the fan was. I went outside and jiggled the thermostat wire and everything worked fine. I got home from work this morning and nothing works. The heat, ac, or fan is not working, but you can manually make the outside unit work. What could this possibly be??
Denhamjw is offline   Reply With Quote
Old 06-29-2008, 11:22 AM   #2
oops, did I do that!
Have you trimmed any weeds around the outdoor unit lately? May have cut and/or shorted stat wires from the indoor unit.
If nothing works the transformer may have failed, and unless your an electrician or a qualified service tech, you may want to call for service.
8 Ball is offline   Reply With Quote
Old 06-29-2008, 01:48 PM   #3
Just changed the transformer....still doesnt work...shouldnt there be a fuse somewhere?? If so where would it be?
Old 06-29-2008, 03:07 PM   #4
ok im an idiot. I changed the transformer to the doorbell instead of the a/c unit. LOL it works now
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 11:52 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
