Thermostat??? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 11:00 AM   #1
Thermostat???
Hi.... I've got a Carrier hvac system. It was installed in 2010 so fairly new.
They company installed a Honeywell TH6110 programmable thermostat and up until about three weeks ago performed flawlessly. Now it's intermittent.
Sometimes it will work fine and other times will not turn on at setting. Right now it's set for 69 on a temporary setting and it is dropping below to 63 without turning on. It won't come on even if I raise it to 72. But then, a half hour later will work fine.
Anyone else hear of this?
Thanks in advance. Tom
Tom Henry is offline   Reply With Quote
Old 01-23-2013, 11:04 AM   #2
Roofmaster
Rewards Points: 2,172
Hi Tom,
Does this take batteries? If not I would suspect dirty contacts, or a bad transformer?
Old 01-23-2013, 11:05 AM   #3
Roofmaster
Hi Tom,
Does this take batteries? If not I would suspect dirty contacts, or maybe a bad transformer?
Old 01-23-2013, 11:06 AM   #4
Yes. I have put in fresh Duracells in
Old 01-23-2013, 12:35 PM   #5
Rewards Points: 484
Usually a transformer just quits and never works again. The problem may indeed be the thermostat but it could also be a problem with the furnace.
Since this is a fairly new install, I would have the installer come out and check it but if you wanted to, next time it acts up, remove the thermostat and run a jumper between R and W and see if the furnace starts.
sammy37 is offline   Reply With Quote
The Following User Says Thank You to sammy37 For This Useful Post:
jagans (01-23-2013)
Old 01-23-2013, 12:37 PM   #6
Rewards Points: 484
When you raise the thermostat above the room temp, do you hear it click? If yes, than its usually pretty safe to say that the thermostat is working and the furnace would be suspect.
Old 01-23-2013, 01:10 PM   #7
I had the installer on call and found out it was $99 for the service call and the first half hour. They couldn't come until tomorrow. Seeing that this not a dead hvac or something that is an emergency, I told them no thanks for now.
I didn't hear a click when raising the temp. When I set it to just fan, it would come on. when I turned it back to auto, the fan stopped.
But I did pull the thermostat off the wall to check the wiring. Everything looked in order and after I snapped the thermostat back in place, I adjusted the temp upwards and the furnace started heating.
Could it be a dirty contact?
Old 01-23-2013, 01:40 PM   #8
Roofmaster
Yup, it sure could. CRC QD Electronic spray at your local WalMart. I even use it for starting fluid!
Old 01-23-2013, 01:47 PM   #9
Thanks. I'll try it and report back.
Old 01-23-2013, 03:32 PM   #10
Roofmaster
Sounds like you already fixed it. Just the friction between dirty contacts can clean them enough to complete the circuit, and you probably had marginal batteries.
Old 01-31-2013, 10:52 AM   #11
Well...... as it happens.... not all things are as they appear.
After more issues with the thermostat not keeping the temp near the setting, I replaced it with a new one.
I got lucky and found a compatible Honeywell model and it was easy to change even though I had to change the base plate.
Thanks for your help sammy37 and jagans.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
