Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 08:34 AM   #1
thermostat
I never use my central air. it is set to off. fan has on or auto setting. It has always been set to auto, and does not go on, which is the way i want it. the other day, the fan started going on and off...and will not stop. no matter where i have the thermostat set..it keeps going on and off. what's up with that? thanx in advance for your time!
Zelvis is offline   Reply With Quote
Old 08-07-2012, 09:09 AM   #2
Could be any number of things, from a faulty board, to a faulty wire, faulty limit, faulty tstat ... the list goes on for a bit.
You can eliminate certain things pretty easily - for example, remove the G wire from the tstat wiring terminals. If the fan issue stops, then most likely the tstat is bad. If it continues, the stat is not your trouble.
scottmcd9999 is offline   Reply With Quote
Old 08-07-2012, 06:55 PM   #3
post model and serial # s. Could be many things but some units have fan relay which are know for these type of failures.
turnermech is offline   Reply With Quote
Old 08-07-2012, 09:34 PM   #4
Missouri Bound's Avatar
Where is your furnace located in your home and where do you live?
Do you want it your way or the right way?
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
