-   -   thermostat (http://www.diychatroom.com/f17/thermostat-152896/)
Zelvis 08-07-2012 07:34 AM
thermostat
I never use my central air. it is set to off. fan has on or auto setting. It has always been set to auto, and does not go on, which is the way i want it. the other day, the fan started going on and off...and will not stop. no matter where i have the thermostat set..it keeps going on and off. what's up with that? thanx in advance for your time!
scottmcd9999 08-07-2012 08:09 AM
Could be any number of things, from a faulty board, to a faulty wire, faulty limit, faulty tstat ... the list goes on for a bit.
You can eliminate certain things pretty easily - for example, remove the G wire from the tstat wiring terminals. If the fan issue stops, then most likely the tstat is bad. If it continues, the stat is not your trouble.
turnermech 08-07-2012 05:55 PM
post model and serial # s. Could be many things but some units have fan relay which are know for these type of failures.
Missouri Bound 08-07-2012 08:34 PM
Where is your furnace located in your home and where do you live?
