Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 06:11 PM   #1
Thermostat
My Weathertron thermostat's red "emergency heat" light has been flashing at differfent times today. (I have a heat pump.) What does this mean? Should'nt the green "auxillary" light be on ?
JRWR is offline   Reply With Quote
Old 01-24-2012, 06:14 PM   #2
it means you are heating only on your supplemental heat and the heat pum \p is not putting out heat.
Would help to know how cold it is where you are now. And how old your unit is with a model number if you have it.
hvac5646 is offline   Reply With Quote
Old 01-24-2012, 06:42 PM   #3
sktn77a's Avatar
Rewards Points: 392
If your auxilliary heat is kicking in, the AUX heat light should be lighting up but not the EMER light. However, your system may be wired in such a way that what you are describing is how it works. Has it always done this?
sktn77a is offline   Reply With Quote
Old 01-24-2012, 09:51 PM   #4
REP
Question ,does your emgr heat come on when you go into defrost?
REP is offline   Reply With Quote
Old 01-25-2012, 01:10 AM   #5
Lot of times the Eheat and aux heat are using the same wire jumped inside the tstat so when it goes into aux heat ie; too cold outdoors the light for eheat will come on.
Baldrick is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 05:35 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
