Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 09:27 AM   #1
Thermostat
My totaline thermostat is blank
jeffreyjmcmahon is offline   Reply With Quote
Old 10-02-2011, 09:33 AM   #2
We will be glad to help you, a little more information would be helpful.
What type of system is this?
Have you checked anything yet?
There may be float (water) switches in the drain system.
Master of Cold is offline   Reply With Quote
Old 10-02-2011, 09:34 AM   #3
Experienced
Jackofall1's Avatar
Hello jeffreyjmcmahon, to the best darn DIY'r site on the web.
Sounds to me like the batteries need to be replaced.
Mark
Old 10-02-2011, 09:40 AM   #4
thermostat
I don't see any batteries in this thermostat
Old 10-02-2011, 09:58 AM   #5
The thermostat is blank due to a loss of input power, or thermostat failure.
Do you have a volt meter?
Old 10-02-2011, 10:04 AM   #6
thermostat
No, I don't have one on hand I doubled checked the breaker box, There is a red light on in the furnace which is suppose to be normal. I do believe the pilot light is out. I am not sure if that has anything to do with it.
Old 10-02-2011, 10:10 AM   #7
You will need a meter to proceed further. A cheap meter ($15) from home depot will suffice.
The Following User Says Thank You to Master of Cold For This Useful Post:
jeffreyjmcmahon (10-02-2011)
Old 10-02-2011, 10:17 AM   #8
I have checked the breaker. The furnace seems to be getting power but I don't see the pilot light coming on . Someone else suggested the batteries in the thermostat but I don't see any batteries.
Old 10-02-2011, 10:18 AM   #9
Thermostat
It it reads that it is bad do I buy a new thermostat to replace it
Old 10-02-2011, 10:21 AM   #10
HVAC Tech/ Browns Fan
may just have bad t-stat. It maybe hooked up hot on com. If the read light is on the board that is sign of power. But you may have blowen 24. there should be a car 3 amp fuse on board. If its blowen then you have a short some were maybe a mouse inside out door unit just ate up wire
Tator1076 is offline   Reply With Quote
Old 10-02-2011, 10:22 AM   #11
Unless you want me to tell you to stick your tounge on the red wire, your going to need a meter if you want to "do it yourself".
Old 10-02-2011, 10:25 AM   #12
Hey its only 24 volts only make him jump
Old 10-02-2011, 10:28 AM   #13
thermostat
Thanks for the humor.. I needed to laugh, I got a garage door broke , the oven and now the furnace.. You got to laugh
Old 10-02-2011, 10:35 AM   #14
Rewards Points: 492
If you truly have a thermostat w/out battery or batteries, check by the furnace for an (emergency) switch which many people throw off for the season. This might be what provides power to thermostat. If you find it, give thermostat a little time to charge and so panel can be read.
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
Old 10-02-2011, 10:42 AM   #15
The stat shold come on instantly. It has lost the 24 volt power supply, or has failed.
Its a totaline stat, so complete failure is not surprising.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
