-   -   Thermostat (http://www.diychatroom.com/f17/thermostat-118955/)
jeffreyjmcmahon 10-02-2011 08:27 AM
Thermostat
My totaline thermostat is blank
Master of Cold 10-02-2011 08:33 AM
We will be glad to help you, a little more information would be helpful.
What type of system is this?
Have you checked anything yet?
There may be float (water) switches in the drain system.
Jackofall1 10-02-2011 08:34 AM
Hello jeffreyjmcmahon, to the best darn DIY'r site on the web.
Sounds to me like the batteries need to be replaced.
Mark
jeffreyjmcmahon 10-02-2011 08:40 AM
thermostat
I don't see any batteries in this thermostat
Master of Cold 10-02-2011 08:58 AM
The thermostat is blank due to a loss of input power, or thermostat failure.
Do you have a volt meter?
jeffreyjmcmahon 10-02-2011 09:04 AM
thermostat
No, I don't have one on hand I doubled checked the breaker box, There is a red light on in the furnace which is suppose to be normal. I do believe the pilot light is out. I am not sure if that has anything to do with it.
Master of Cold 10-02-2011 09:10 AM
You will need a meter to proceed further. A cheap meter ($15) from home depot will suffice.
jeffreyjmcmahon 10-02-2011 09:17 AM
I have checked the breaker. The furnace seems to be getting power but I don't see the pilot light coming on . Someone else suggested the batteries in the thermostat but I don't see any batteries.
jeffreyjmcmahon 10-02-2011 09:18 AM
Thermostat
It it reads that it is bad do I buy a new thermostat to replace it
Tator1076 10-02-2011 09:21 AM
may just have bad t-stat. It maybe hooked up hot on com. If the read light is on the board that is sign of power. But you may have blowen 24. there should be a car 3 amp fuse on board. If its blowen then you have a short some were maybe a mouse inside out door unit just ate up wire
Master of Cold 10-02-2011 09:22 AM
Unless you want me to tell you to stick your tounge on the red wire, your going to need a meter if you want to "do it yourself".
Tator1076 10-02-2011 09:25 AM
Hey its only 24 volts only make him jump
jeffreyjmcmahon 10-02-2011 09:28 AM
thermostat
Thanks for the humor.. I needed to laugh, I got a garage door broke , the oven and now the furnace.. You got to laugh :laughing::laughing::laughing:
diyorpay 10-02-2011 09:35 AM
If you truly have a thermostat w/out battery or batteries, check by the furnace for an (emergency) switch which many people throw off for the season. This might be what provides power to thermostat. If you find it, give thermostat a little time to charge and so panel can be read.
Master of Cold 10-02-2011 09:42 AM
The stat shold come on instantly. It has lost the 24 volt power supply, or has failed.
Its a totaline stat, so complete failure is not surprising.
