#1 |
Thermostat
Does anyone have any recommendations for a thermostat that has a remote sensor that can be carried to the living room or the master bedroom if needed..
This will be be for a heat pump system Lennox 14HPX-060 Condenser CBX26UH-060 Air Handler***** ECB26-15CB Heat Strips. D |
#2 |
Professional
Thermostat
Honeywell wireless including remote YTH6320R1015
http://www.forwardthinking.honeywell..._focus_pro.wmv
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by hvactech126; 05-19-2011 at 11:27 PM. |
#3 |
Thermostat
Thanks He doesnt want to put that one in because he thinks the dehumidify feature will cause problems since its so humid down here.. I didn't see a dehumidify feature when I looked at the manual?
d |
#4 |
An old Tradesmen
Thermostat
A dehumidify feature won't interfere with anything. Since you have to enable it for it to do anything. Next, that feature is for areas that have high humidity. He doesn't know what he is talking about.
| The Following User Says Thank You to beenthere For This Useful Post: | dbmet (05-21-2011) |
#5 |
Thermostat
Thanks..beenthere.. Guess I'm off to look for a different dealer or figure out how to install this on my heatpump system...Hmm...
QUOTE=beenthere;652313]A dehumidify feature won't interfere with anything. Since you have to enable it for it to do anything. Next, that feature is for areas that have high humidity. He doesn't know what he is talking about.[/QUOTE] |
| Display Modes | |
| Thermostat issues on old furnace - questions before I replace thermostat. | Calab | HVAC | 11 | 02-18-2012 09:43 AM |
| weathertron Mecury Thermostat | VickiL | HVAC | 4 | 02-06-2011 05:32 PM |
| Thermostat issues | rathipon | HVAC | 4 | 01-29-2011 12:46 PM |
| Carrier Edge Thermostat Installation Issue | ptalar | HVAC | 1 | 07-13-2010 06:40 PM |
| Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System | TekGamer | HVAC | 0 | 07-10-2010 12:58 AM |
