Old 09-20-2012, 09:22 PM   #1
Thermopile millivolts?
I have a gas fireplace (fireplace xtrodinair) thats about 11 years old and it would not ignite today.The pilot was on. I cleaned the thermocouple and the thermopile. I reinstalled them and got the pilot back on but the gas valve once again would not open. I have been given two different millivoltages to look for on the thermopile 330 and 750. I checked mine and found it to be around 380 - 400 mv range. How should I be able to find out if its the robertshaw gas control or the thermopile that is giving me trouble?
Gary Cski is offline   Reply With Quote
Old 09-20-2012, 10:12 PM   #2
how
Is the gas valve turned from the pilot position back to "on" again?
Do you have an on/off switch, remote or a thermostat to control the fireplace with?
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Gary Cski (09-20-2012)
Old 09-20-2012, 10:42 PM   #3
Yes the gas is back to the on position...I have a remote thermostat that controls the unit. I have checked the remote and taken the remote function out of the system in order to try and get the unit to fire. I have also "shorted" the wires going to the thermostat control to simulate the on possition...none has resulted in any gas turning on.
Old 09-20-2012, 10:46 PM   #4
did you try tapping on the gas valve may be stuck from setting.....just fixed one vanguard....its been working fine since...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 09-20-2012, 10:51 PM   #5
Yes I have tried tapping ...with no luck, but thanks.
Old 09-21-2012, 02:31 AM   #6
how
At your measured powerpile output/ with good connections to the gas valve/with thermostat lines jumpered at the gas valve/ with all gas cocks fully open & the gas valve "on"....if it isn't opening...
change the valve.
Gary Cski (09-21-2012)
Old 09-21-2012, 05:07 AM   #7
Is my 400 millivolts from the thermopile enough to open the valve or should it be higher? I've been told it should be closer to 700mv. Just wondering.
Old 09-21-2012, 07:44 AM   #8
it dosen't hurt to have a few repair parts handi....while i want to agree with how....I think I would change out the thermopile 1st because if my old memory recalls i want to say millivolts should be closer to that 700 range,,,,but have to admit don't do alot of millivolts systems...rusty.... ben sr
Old 09-21-2012, 12:00 PM   #9
how
Thermopiles are cheap & easy parts to change (as ben points) out where as fireplace gas valves can often be the most difficult to access.
If you are measuring a thermopile while it is connected to a robertshaw valve, if it measures 326 MV or higher while the thermostat circuit is open, the power pile is considered strong enough to open the valve.
Your output seemed to be 50MV above that threashold.
Were you measuring your powerpile output when it was connected to the gas valve or on it's own?
Was the thermostat was on or not?
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (09-21-2012), Gary Cski (09-21-2012)
Old 09-21-2012, 04:46 PM   #10
How and I are probably going to have to agree to disagree on this but, if you are only getting around 400Mv from the power pile then I would replace it first. I have never had one in 35 years of heating systems work well at that low of a voltage. I woild first ensure the powerpile is fully enveloped in the pilot flame when testing it.
danpik is online now   Reply With Quote
Old 09-21-2012, 05:19 PM   #11
I have taken readings with the thermopile wired to the valve, unhooked from the valve, thermostat open and closeds and all my readings come back between 380 and 400 mv.
Old 09-21-2012, 05:22 PM   #12
To Dan, The flame is centered on the thermopile and enveloping the top 1/3 of the thermopile.
Old 09-21-2012, 05:25 PM   #13
At this point I am going to purchase a new thermopile and valve. The shop will take the valve back if not used. I will hook up the new thermopile to the old valve and see if it works , if not I will install the valve and hope one of these two items fix the problem.....if not I will be back on later this weekend.
The Following User Says Thank You to Gary Cski For This Useful Post:
Old 09-21-2012, 09:16 PM   #14
Should be good. The key is to have the probe "IN" the flame. I have seen some that the flame was so low that the flame was barely touching the probe which will not generate enough power.
Let us know how it works out for you.
The Following User Says Thank You to danpik For This Useful Post:
Old 09-21-2012, 09:57 PM   #15
how
Hey Gary
This may clarify RobertShaw's recomendations on powerpile measurements on their gas valves.
Goggle
www.robertshawtstats.com/spaw2/.../ControlTips-MillivoltSystems.pd...
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Millivolts Using A Voltage Meter (Tester) Needtolearn Appliances 2 07-14-2012 08:06 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Need advice for gas hot water problem, please!! YerDugliness Plumbing 20 08-11-2008 11:17 PM
