Thermocouple Question - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2006, 12:56 AM   #1
Are natural gas and propane thermocouples the same or are they different for each gas?
blue82001 is offline   Reply With Quote
Old 06-14-2006, 11:00 AM   #2
They both should be the same.
I have only worked on natural gas and not propane.
The thermocouples work off of sensing the heat present and not the type of gas.
If heat is present than a miili amp of current is sent to the gas valve to allow gas thru the valve. If there is not heat present at the thermocouple then than gas will not flow thru the gas valve. Safety feature.
redline is offline   Reply With Quote
Old 06-14-2006, 02:40 PM   #3
Sciencerules
MAS2006's Avatar
The mechcanical thermal couples should be the same. The valves are slightly different, gas pressure of liquid propane and natural gas are different. Electrical thermal couples are dissimilar metals welded together, and produce microvolts/degree of temperature, based on how designed.
MAS2006 is offline   Reply With Quote
Old 07-14-2006, 05:41 AM   #4
Make sure it's a thermcouple and not a thermopile.
oddjob is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Outdoor Slate Question (with pictures) kabbak Flooring 2 07-05-2006 04:02 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-25-2005 12:40 AM
