Is This A Thermocouple? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 02:09 PM   #31
hi the red rubber looking item that looks like a spark plug is the ignitor ,, there shu be another metal rod in that pilot assy that.. is there ? maybe remove that metal plate so clear pic of assy
hvac dude is offline   Reply With Quote
Old 01-05-2013, 04:48 PM   #32
An old Tradesmen
Rewards Points: 6,060
Originally Posted by hvac dude View Post
i may have missed it but i didnt see any where where it says you have cleaned the flame sensor have you tried cleaning it yet ?
A dirty flame sensor won't prevent ignition. It only shuts down the burner after ignition if no flame is sensed.
Old 01-05-2013, 04:55 PM   #33
process of elimination sir ... his story said sometimes it fires and sometimes it dosent and havent determined weather its lockng out or shutting dwn during cycle ,, unless you know as i dont
Old 01-05-2013, 05:04 PM   #34
An old Tradesmen
No, I take his saying its not lighting as its not lighting. Most people say it lights then goes right back out when its a dirty flame sensor.
Old 01-05-2013, 06:44 PM   #35
graf,,,,, walk us thru some cycles and what you do to get it going once it it dosent lite pls n ty
Old 01-05-2013, 07:11 PM   #36
Ok. The pilot will light almost always, the burners will light and sometime the pilot will go out after after a few minutes and the burners fail to light.
graffij1 is offline   Reply With Quote
Old 01-05-2013, 09:30 PM   #37
sequence of opereation:
1 pilot lites first
2 flame senser senses pilot flame
3 the main burners lite off once senser senses pilot flame
4 no flame detected system may lock out depending on type
so try cleaning the flame sensor first step then we go from there, these valves are common for failing and causing intermittant problems but let try the less costly approch first
Old 01-06-2013, 08:08 AM   #38
Roofmaster
Rewards Points: 2,172
If you dont know the difference between a gas valve and a Thermocouple, you have no business being inside a furnace my friend. You need to hire a pro, go to school, read a lot, or all three.
Old 01-06-2013, 08:50 AM   #39
wow jagans aren't you a peach.
Old 01-06-2013, 09:13 AM   #40
Roofmaster
Just trying to save you, or your families life. NG + Oxy = Potential Bomb, just add spark.
Old 01-06-2013, 09:16 AM   #41
well thanks for your concern. the point of the thread besides getting my heater fixed is to learn something.
Old 01-06-2013, 09:30 AM   #42
An old Tradesmen
So did you clean the sensor. And if so is it working correctly now.
Old 01-06-2013, 09:43 AM   #43
I'm going to clean it when I get home. I have morning filled with futsal games. I'll post an update after I clean it.
Old 01-06-2013, 10:02 AM   #44
Rewards Points: 196
The sparker electrode is also the flame sensor.You need to clean the electrode.Small strip of emery cloth works good to remove the carbon buildup so its nice and polished looking.The gas valve isn't a smartvalve.Picture i'm looking at showing a standard honeywell intermittant ignition valve with a honeywell s8610u ignition control below it.
HVACTECH96 is offline   Reply With Quote
Old 01-06-2013, 11:06 AM   #45
i noticed the igntion module after i saw the last pic posted tech96 ty
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 08:24 PM
Thermocouple nut problem w/ gas fireplace movick724 Appliances 1 11-08-2011 04:00 AM
Thermocouple and Gas Valve dimjim HVAC 10 03-22-2011 11:05 PM
How long for the thermocouple to shut off the gas? dashworth HVAC 4 10-29-2010 09:41 PM
