Is This A Thermocouple? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 09:44 AM   #16
Rewards Points: 610
The pilot may be too small and thus not impinging on the flame sensor adequately. Try tapping on the pilot line to dislodge any dirt or debris out of the pilot assembly to increase pilot flame. If pilot still too small you may have to remove it to clean it out. You can also remove the pilot supply line at the valve and try blowing threough it to clear blockage. Pilot orifice is very small so you may not feel that you are blowing through it. Just reassemble and try again. Be careful not to cross thread the connection. Should turn in by turning with fingers if not then realign and keep trying. Do not force it.
techpappy is offline   Reply With Quote
Old 12-29-2012, 10:02 AM   #17
Okay so what do I do with it?
graffij1 is offline   Reply With Quote
Old 12-29-2012, 10:28 AM   #18
jkjkjkjkj
hvac5646 is offline   Reply With Quote
Old 12-29-2012, 12:02 PM   #19
Thanks tech Pappy. I turn the gas off at the valve correct?
Old 12-29-2012, 10:13 PM   #20
Rewards Points: 610
Correct .. clean with fine brush and blow through again and reassemble If that doesn't work then try cleaning in warm water to loosen debris and retry ....OR may have to replace pilot assembly...the orifice is very fine so do not try to clean out with any type of probe...let us know how you make out..hoping for success
Old 12-29-2012, 10:20 PM   #21
I turned it off at the valve, unhooked what I believe was the pilot line blew on it and hooked it back up. It seems to be working properly now, if I wake up to a cold house tomorrow I'll be back. But thanks for getting me to this point.
Old 12-29-2012, 10:35 PM   #22
Rewards Points: 610
Did the pilot appear larger? If so..should be good. Let us know if you wake up to a warm house tomorrow!
Old 01-03-2013, 11:30 PM   #23
hi that valve is a honeywell smart valve.. did u correct the problem ?
hvac dude is offline   Reply With Quote
Old 01-04-2013, 06:25 AM   #24
No I still have to keep the cover off. For the burners to light consistently.
Old 01-04-2013, 07:26 AM   #25
keep the front panel off you mean ? walk us thru the sequence whats happening ?
Old 01-05-2013, 08:55 AM   #26
The burners consistently light when I have it like this.
The burners don't catch when I have it like this.
Old 01-05-2013, 11:51 AM   #27
does it light every time with door off ? and does it not light every time with door on ,, or is it intermmitant ?
Old 01-05-2013, 11:54 AM   #28
Not everytime with the door off but most of the time. With the door on it lights some of the time but not enough to keep the house warm it may go a couple hours,without lighting when the door is on
Old 01-05-2013, 12:23 PM   #29
i may have missed it but i didnt see any where where it says you have cleaned the flame sensor have you tried cleaning it yet ?
Old 01-05-2013, 01:04 PM   #30
I have not tried to clean the flame sensor. I would suspect its connected to the red tube, would you agree?
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 07:24 PM
Thermocouple nut problem w/ gas fireplace movick724 Appliances 1 11-08-2011 03:00 AM
Thermocouple and Gas Valve dimjim HVAC 10 03-22-2011 10:05 PM
How long for the thermocouple to shut off the gas? dashworth HVAC 4 10-29-2010 08:41 PM
