Is This A Thermocouple? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 07:48 PM   #1
is this a thermocouple?
Everything I've read about thermocouples are they are copper but I don't have copper in here. Its the pipe coming out of this valve right? Just for terrence I've got a heil nuge075bg01
graffij1 is offline   Reply With Quote
Old 10-08-2012, 07:51 PM   #2
Rewards Points: 3,130
No. I see no thermocouple anywhere in that picture.
Old 10-08-2012, 07:52 PM   #3
Good thing I didn't take it off then. What would be the gray tube coming out if the valve?
Old 10-08-2012, 07:54 PM   #4
I'm having a hard getting pilot to keep reigniting. Would like to set thermostat to auto
Old 10-08-2012, 08:56 PM   #5
Rewards Points: 1,294
I believe that gas valve is an intermitent pilot valve. The tube you see is the pilot supply tube. There should be a spark ignitor to light the pilot.
danpik is offline   Reply With Quote
Old 10-08-2012, 08:59 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
If you had one this is what it'd look like. It would not be by the gas valve where you pictured but rather in the burner compartment.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-08-2012, 10:58 PM   #7
An old Tradesmen
Rewards Points: 6,140
Moved to HVAC forum.
Old 10-08-2012, 11:21 PM   #8
Rewards Points: 610
The unit is not equipped with a thermocouple. Has electric spark or glow coill ignition with a flame rod, flame sensor which completes voltage to gas valve when the pilot is lit and the sensor (flame rod) is working and senses the existence of the pilot flame. So, pilot should light first then, as long as the flame rod senses the flame the gas valve will open. If pilot lights then goes out then the sensor/flame rod is dirty or defective..try cleaning first..It is located next to the pilot assy and looks like a little porceline holder with a metal rod attached..the metal probe is positioned to have the tip in the pilot flame
Let us know if the pilot lights
OR..could be a "power pile" which is similar to a thermocouple but has two wires from it to the gas valve..
techpappy is offline   Reply With Quote
Old 10-08-2012, 11:57 PM   #9
how
Rewards Points: 1,070
I believe I see a grounding wire on the pilot base assy which says its spark ignition.
No thermocouple....Uses rectifyer..flame rod.
how is offline   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (10-09-2012), carmon (10-09-2012)
Old 10-09-2012, 07:47 AM   #10
Techpappy you got it the pilot lights then goes out. I had a buddy out like two years ago and he cleaned it out. I'm not really trying to ask him to come over again for this. Is this something I could clean myself any how tos on the Web?
Also thanks for moving to the HVAC forum, whoever did that
Old 10-09-2012, 09:36 AM   #11
The flame rod looks like a wire that stcks out into where the pilot flame is burning when lit.
They can sometimes be a bit of a hassle to get to. There will be a single wire coming from the end of it. It will also have a white or light grey ceramic insulator around it. Use a piece of fine steel wool to shine it up. Also check the connections to make sure there is no corosion on the connections on both the sensor and the board it is hooked to
Old 12-29-2012, 06:34 AM   #12
So here is the thing. I did nothing to clean anything I just took the cover off the front of the furnace and the pilot lights regularly...now I know this isn't right but it's been working for the past two months. I finally have time to fix it. what should I try first? Cleaning the flame rod?
Old 12-29-2012, 08:16 AM   #13
An old Tradesmen
Yes, but carefully.
Old 12-29-2012, 09:50 AM   #14
only two leads off valve...standard redundant valve.
hvac5646 is offline   Reply With Quote
Old 12-29-2012, 10:00 AM   #15
...jjjjj
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 08:24 PM
Thermocouple nut problem w/ gas fireplace movick724 Appliances 1 11-08-2011 04:00 AM
Thermocouple and Gas Valve dimjim HVAC 10 03-22-2011 11:05 PM
How long for the thermocouple to shut off the gas? dashworth HVAC 4 10-29-2010 09:41 PM
