Thermal Overload - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 12:35 AM   #1
Still Learning
thermal overload
Ok so you know how the compressors have that thermal protector in series with the run terminal? Well why would it ever make a ticking noise?? I just got this copeland compressor rebuilt because it was stuck. It ran with no refrigerant for too long I guess. Well its rebuilt and all charged up, but when I plug in the freezer it makes a ticking noise. And I put my meter in the run and L2 and I got 120v. Then after the thermal overload clicked it went down to 0v, and when it ticked again it went back to 120v. The capacitor is good... its like its trying to start but its not... I don't want to bypass the overload to see if that's the problem... any advise?
thehvacguy is offline   Reply With Quote
Old 08-25-2011, 06:37 AM   #2
biggles's Avatar
is the top of the compressor hot to the touch...the thermal shouldn't be opening then closing it reacts to the casing of the compressor when it is hot...not the wires going in and out of it.need an amprobe to see the starting amps.
Old 08-25-2011, 09:40 AM   #3
Still Learning
No, the compressor is not hot. It has not turned on in months. Like I said I just got it rebuilt and charged...
Old 08-27-2011, 11:05 PM   #4
Still Learning
I just noticed a burn mark on the underside of the lid of the electrical box on top of the compressor... it looks like it eminated from the run terminal... I still can't comprehend this phenomina...
Old 08-27-2011, 11:19 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
How do you know its overloading? That works on temp and takes time to reset.
Doc Holliday is offline   Reply With Quote
Old 08-27-2011, 11:28 PM   #6
And what do you mean by plugging in a freezer? Same circuit?
Old 08-28-2011, 07:56 AM   #7
An old Tradesmen
Rewards Points: 6,824
Does it have a start capacitor and potential relay?
Old 08-28-2011, 10:51 PM   #8
Still Learning
There is a start cap and a relay under it. The microfarads are right on the capacitor... but I plug in the freezer, and the fans come on. Then I hear the compressor make a "tick" kinda noise. It comes from the electrical box on top of the compressor. I can actually feel it move when I'm holding my meter to run and L2. When it ticks I get 0v on the meter. Then a few seconds later, maybe 10-15 seconds, it ticks again, and the voltage reads 120v. Like the voltage is going to the compressor and nothing happens... I just got it rebuilt it should work...
Old 08-29-2011, 04:16 AM   #9
An old Tradesmen
Check your voltage from start to common on the compressor.
Old 08-29-2011, 01:59 PM   #10
Still Learning
Are you going to say to replace the capacitor if its low?
Old 08-29-2011, 05:21 PM   #11
AKA HVACTECHFW
Rewards Points: 1,208
how did you get the compressor rebuilt?! Most Freezer compressors are hermetic..... (sealed) units............
You cant check a start capacitor unless you remove the bleed resistor............
Does the compressor call for 120V or 240V?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-29-2011, 05:32 PM   #12
An old Tradesmen
Probably gonna say replace the start cap and potential relay.
Old 08-29-2011, 05:55 PM   #13
Still Learning
Its a commercial reach in with a copeland semi hermetic compressor. Its 120v.
Old 08-29-2011, 06:03 PM   #14
Still Learning
Ok. But can you explain the technical aspect of why that would be? I was taught that you check the microfarads coming off the capacitor and as long as it meets the requirements then its good. Am I missing something?
Old 08-29-2011, 06:20 PM   #15
Still Learning
Also would this be a situation where one would use a hard start kit?
Installation of Thermal Cable RenoMom Flooring 1 07-18-2011 09:45 PM
Thermal audit on new build (thermal pics) danreg99 General DIY Discussions 0 03-14-2011 07:38 PM
Gas water heater thermal limit keeps tripping KAdams4458 Plumbing 14 05-20-2010 07:08 PM
Electrical Baseboard Thermal Protection Blade_316 Electrical 5 10-22-2009 05:51 AM
Thermal Barrier Windows vs Vinal Windows MeraleeCrowl Remodeling 6 11-05-2008 04:46 PM
