Is There A Trick To Twist Fitting Type B Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 07:33 PM   #1
Rewards Points: 1,062
Question
is there a trick to twist fitting type B vents
when done by a single person?? because when i twist and click one end, i undo the other. it is very annoying. i tried gorilla taping the already done joints but that's kindof high maintenance as well and works with varying degree of success.
it is possible to have two people do it but that is impractical because i am working in a tight area under the ceiling and it is hard to reach. i also have only one step ladder. with 6" vents, it is really hard to twist with one hand while holding the other vent with the other because you need more grip and need to use both hands.
so i was wondering if there are any tricks to doing it. it is very frustrating to twist one on just to discover the other end was untwisted by doing so...
Old 07-14-2011, 07:57 PM   #2
JJboy's Avatar
http://www.google.com/url?sa=t&sourc...jAO_9w&cad=rja
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-14-2011, 08:21 PM   #3
so basically, use sheet metal screws to stop it from moving once clicked on?
Old 07-14-2011, 09:22 PM   #4
30 year tech
hvac122's Avatar
What brand are you using? Shouldn't need to use screws. If you do don't penetrate the inner liner as it will ruin the integrety of the double wall.
hvac122 is offline   Reply With Quote
The Following User Says Thank You to hvac122 For This Useful Post:
amakarevic (07-14-2011)
Old 07-14-2011, 10:08 PM   #5
Simpson DuraVent
Do I need to replace soffit vents?? And other roofing questions. kennykenny Roofing/Siding 5 04-17-2011 09:22 AM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 06:20 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 07:32 AM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
