Is There Such An Item? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 02:07 PM   #1
Rewards Points: 292
Is there such an item?
I have a couple of runs (very long) that could use a little more airflow. I have tweaked the dampers to their optimum settings.
Is there a commercial product, I'll call it a 'scoop', which could be inserted into the takeoff to 'direct' the airflow (sort of a ram effect)? Currently, the takeoffs are taken from the top of the trunk and immediately elbow.
If no such product, what do you think of such an approach?
V
veesubotee is offline   Reply With Quote
Old 09-01-2010, 06:45 AM   #2
There are scoops available, but also booster fans for long rungs that can be t-stat controled.
lamon2524 is offline   Reply With Quote
Old 09-01-2010, 05:27 PM   #3
An old Tradesmen
Rewards Points: 7,414
You can get scooped take offs.
Sounds like you got some undersized duct work.
Old 09-01-2010, 05:54 PM   #4
Problem was that they did not reduce the long run, should have went 18, 16 ,14, 12 that way static pressure would compensate.
Old 09-01-2010, 06:13 PM   #5
An old Tradesmen
Reducing trunk line is only needed if the trunk is over 24' in length. As long as its not. no problem with velocity, or static regain.
If the problem is the trunk is over 24' and the near registers are the ones that don't get enough air flow. Then it should have been reduced. if its the far registers, then its undersized.
Anyone know what this hardware item is? Havoc General DIY Discussions 2 12-04-2009 12:00 AM
Cool Tools Builders' Show 2009 in Vegas -item help DesertPaso Tools 7 09-24-2009 01:41 AM
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 06:14 PM
