Old 02-11-2012, 10:38 PM   #1
Is there a standered specing for furnace vent pipes?
I'm in need of a hot water heater and I'm planing on installing a power vent model. That brings up the probable of the best placement of the venting for the hot water heater and someday a high efficiency furnace.
I would like to make the best choice possible very hard when not doing both. Can a furnace have both intake and exhaust in the same stud bay? Is there a standard dimension for spacing of holes? When I make the hole for the new water heater I would like to have a backup plane if possible.
rodm1 is offline   Reply With Quote
Old 02-11-2012, 11:02 PM   #2
The furnace intake and exhaust can run side by side as they will terminate next to each other. As for the termination, it depends on what the manufacturer allows. Could be a concentric, a bay vent or just two pipes. The holes will also depend on what size venting you use, most use 2", but higher btuh furnaces require larger pipes. You'll have to do a heat loss to figure out the sizing of your furnace. Also, you'll have to follow the manufacturer's specs of both the water heater and the furnace as to the clearance issues of the vent terminations, as well as all applicable codes (eg. The intake must be 10' from your gas meter's regulator). And finally, I should add that it is because of all of these issues and more that gas appliances must be installed by a qualified person. I know this is a diy site, but I see so many code violations and just simply stupid things done with gas on a day to day basis that I can't stress enough to either do your homework and research diligently, or hire a pro.
hvac benny is offline   Reply With Quote
Old 02-11-2012, 11:12 PM   #3
retired elect/hvac/plumb
plummen's Avatar
And try not to vent them on north side of house if possible to avoid wind/snow and other things blowing in or collecting around them
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Please look at this dryer vent installation Andy Griffith Appliances 6 08-31-2009 01:39 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Extra high vent pipes? fw2007 Plumbing 6 07-11-2008 09:07 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
