Is There A Sealant Or Resin For Fiberboard? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 07:51 PM   #1
Is there a sealant or resin for Fiberboard?
Is there a sealant or resin for Fiberboard that I can use to hold down the fibers. I have to replace a damaged section fiberboard in my system. I bought the fiberboard and see how the fibers come off so I want to see if I can put a sealant or resin on it to hold them down so I won't inhale them when I turn the system on.
ovsims is offline   Reply With Quote
Old 02-17-2011, 08:27 PM   #2
HVAC Tech/ Browns Fan
Just use silver tape on backside.
Tator1076 is offline   Reply With Quote
Old 02-17-2011, 09:09 PM   #3
Not sure if we're on the same page. I want to put something on the side where the fiberglass is not on the side with the aluminum
Old 02-17-2011, 09:12 PM   #4
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
This is one reason why I don't and will never use ductboard. What a stupid idea that crap is. Duct for dummies, all you need is a razor knife, metal tape and some home depot workers and you're ready to do some ductwork! Just dont bump into it... Sorry had to rant on this. Water based duct mastic would seal the fibers in but at $15-$25 per bucket it could get expensive depending on how much area you need to cover
unicursalhex is offline   Reply With Quote
Old 02-18-2011, 12:22 AM   #5
Yeah I wish I could afford to have it replaced. Thanks for the Help
Old 02-18-2011, 12:25 PM   #6
Where did you buy fiber board? I've got some mold in mine and was thinking of just spraying it with Kilz primer. I would replace it if I could find fiber board.
DIY_HVAC is offline   Reply With Quote
Old 02-18-2011, 11:33 PM   #7
I found some at the habitat for humanity REStore
Resin backed aggregate marble or ??? BJM Tiling, ceramics, marble 8 08-10-2010 08:04 AM
Countertop sealant leaves granite with a dull finish? HeyItsJoel Tiling, ceramics, marble 6 05-31-2010 06:00 AM
Can I use this sealant (3M FD150+) on Class B flue? KatieAK Building & Construction 1 04-12-2010 04:35 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
Paint and resin coat countertop elliott Painting 5 11-21-2008 12:21 AM
