Is There A Reason I Shouldn't Disable Second Stage Heat? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 01:59 PM   #16
Rewards Points: 163
Trane documentation states that both stages are 95% efficient. That, of course, is the design specifications under ideal circumstances. When other variables are introduced in the field then you will get different results. If you use a combustion analyzer to determine the actual efficiency of each stage I would think that they would be close to one another even if not at the manufacturers specification. If they are drastically different then there's something wrong with the furnace.
kb3ca is offline   Reply With Quote
Old 01-02-2011, 02:03 PM   #17
An old Tradesmen
Rewards Points: 7,794
Its the furnace design. And part of the install. If it isn't set up with a CA. then first stage is a fair amount lower then second stage out of the box.
Old 01-02-2011, 02:12 PM   #18
Rewards Points: 163
How much is a "fair amount lower"? What's the worse you've seen out of the box? Good information, by the way.
Old 01-02-2011, 02:23 PM   #19
An old Tradesmen
Out of the box, as low as 78%.
Not too many that low though, often mid 80s.
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 05:39 PM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
New Geothermal Heat Pump/Thermostat Problems TMcCrea HVAC 2 01-18-2010 07:40 PM
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 04:55 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
