Is There A Reason I Shouldn't Disable Second Stage Heat? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 09:45 AM   #1
Rewards Points: 392
Is there a reason I shouldn't disable second stage heat?
Ok,
So I have a 1800 sq foot house and I have a two stage 92% Trane 80,000 BTU gas furnace.
Portland's all-time record low was set on February 2, 1950 at 3 below zero.
My House load is such that even at -10 degrees F the first stage would be able to keep up and keep the house warm without going 100%
My question is if I should just disable the second stage all together if I'm not worried about the speed at which it heats the house. The justification would be energy savings.. I waste 6400 BTU per hour running the second stage, and only waste 4160 BTU per hour running the first stage. Now the first stage will run longer and so in theory the same amount of energy is wasted per cycle.. But Isn't the 92% number a combo of a more efficient first stage and less efficient second stage?
I'm thinking of putting a toggle switch on the W1 W2 jumper (single stage thermostat) and if I get super cold or want the furnace to turn on really fast, I'll through the toggle.
Thoughts?
zootjeff is offline   Reply With Quote
Old 01-02-2011, 09:50 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 150
You need to check the temp rise thru the furnace after 10 then 15 then 20 then 25 minutes. It may start to ride/cycle on the limit control. Your bonnet/furnace/ductwork can get progressively hotter after a 10 minute cycle and then the supply temp increases to close to the limit setting if you have marginal sized ducts or minimum airflow. See it happen a lot. Otherwise it should be okay. Will wear out the bearings in your ventor fan a LOT sooner as those suckers run at 3000 or more rpm. Robbing Peter to pay Paul IMO.
Old 01-02-2011, 10:09 AM   #3
Just put a thermostat on that works on temp differential. Second stage will only come on when first stage can not keep the house to temp or for quick warm ups if you use set back.
The AFUE rating is for high fire on all furnaces.
Old 01-02-2011, 10:40 AM   #4
Rewards Points: 392
Are you sure we are talking about the same thing? I'm talking about disabling High heat, not low heat.. I want to run low heat all the time for a longer cycle..
That means less RPM and less heat rise and less heat over longer periods..
Old 01-02-2011, 10:42 AM   #5
Rewards Points: 392
The problem is I just bought a VisionPro8000. And it is only my backup heat.. Right now it's high 20s out so the backup heat is only getting used. The Vision pro has really tight control on the temperature so it cycles a lot..
Is the AFEU rating any better for low heat? How much?
Old 01-02-2011, 10:53 AM   #6
An old Tradesmen
Rewards Points: 7,816
First stage is generally less efficient then second stage.
2 stage is not for saving on fuel, energy cost. Its for comfort.
Old 01-02-2011, 11:03 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 150
On low fire your fan runs at a lower speed so your heat rise may be the same or higher or lower depending on the rpm of the motor, needs checking anyway. The faster you can get the job done (on high fire) the less wear and tear on the ventor and main fan motor. Kinda splitting hairs but some guys like to do this theory stuff. Then again we can argue the energy wasted by the pre and post purge cycle of the burner when it stops and starts. Pull out the Tylenol.
Old 01-02-2011, 11:45 AM   #8
Rewards Points: 392
After 30 minutes it is a 45 degree rise on high heat.
Old 01-02-2011, 11:48 AM   #9
Rewards Points: 392
If that is the case, why would anyone make a two stage furnace?
Old 01-02-2011, 12:00 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 150
Comfort. Lennox and Carrier and others have 3 stage and modulating furnaces. Mods can simulate that nice warm comfy feeling you get from perimeter or hot water heating or infloor heating. The Lennox SLP is 98.2 % efficient and the York is close. You would have to start talking to their design engineers to see the efficiency ratings at different stages but who cares anyway? Go to a movie with the wife and dinner and you blew the savings anyway. Nobody is going to live on bread and water and have rabbbit ear antennas on tube TVs are they?
Old 01-02-2011, 12:02 PM   #11
Rewards Points: 163
I don't believe there is any significant savings by running in first stage only. It takes the same amount of BTU's to satisfy your heat requirement whether you're running in first stage only or both stages. The amount of energy required is the same. However, using first stage exclusively may provide more comfort since the furnace will run longer. As far as the furnace lasting longer, it's a wash I believe.
kb3ca is offline   Reply With Quote
Old 01-02-2011, 12:13 PM   #12
Rewards Points: 392
Yaa I know, it's peanuts.. The problem is that I'm dorking out with it for fun and want to know the nitty gritty. I'v actually put wireless temperature sensors on one of my vents, near my thermostat, and in my office, and I'm graphing it and seeing the results..
In the mild weather, you get a longer run time, and in the extreme cold, you get a bump in heat for extra comfort.
When you jumper W1 to W2 on my Trane, you get 10 minute first stage and then second stage there after...
My run times are pretty consistent around 10 minutes with the Second stage kicking on only after 10 minutes when the house has reached steady state, so only when the furnace comes on in the morning and then again in the evening does it ever hit second stage.... At steady state would you expect a cycle time to be more than 10 minutes? Or is that good?
In my case with an over-sized furnace, I think I'd fall in to the case where I want to avoid short cycle.. What is considered a "short cycle" anyway?
I'm currently cycling about 2.5 times per hour with it 32 degrees outside..
Hmm.. If you are sure that it is less efficient to run on low stage I'm not sure what I should do because that's my goal..
Old 01-02-2011, 12:56 PM   #13
Rewards Points: 163
My Trane furnace is 95% efficient in each stage according to the furnace specifications. You can check the paperwork on your furnace or go on-line to find out what yours is. I have my thermostat (VisionPro IAQ) set to 3 CPH and that seems to work pretty well. My furnace only goes into second stage when it's recovering from setback. Runs in first stage most of the time.
From what you've described I would leave yours pretty much like you have it and get a programmable thermostat if you don't already have one. That may be your best option for increasing overall efficiency.
Old 01-02-2011, 01:16 PM   #14
An old Tradesmen
For comfort.
Thats why they are for comfort.
Old 01-02-2011, 01:18 PM   #15
An old Tradesmen
Check it with a CA, and you'll find out different.
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 05:39 PM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
New Geothermal Heat Pump/Thermostat Problems TMcCrea HVAC 2 01-18-2010 07:40 PM
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 04:55 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
