Theoretical Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 07:27 AM   #1
Rewards Points: 292
Theoretical question
Under the same conditions of (indoor) temperature and humidity, which will cause an air conditioner to run a longer cycle: a higher or lower coil temperature?
veesubotee is offline   Reply With Quote
Old 05-12-2012, 08:16 AM   #2
Experienced
Jackofall1's Avatar
I don't understand your question, a home AC unit is generally setup to controll temperature, therefore one needs a temperature differential from the controlled space, the larger the differential the shorter the cycle.
Realitive humidity allows the air to carry more heat, but this changes as the air is cooled through the coil, condensing water out of the air stream thus reducing pounds moisture, but raising the realitive humidiy at the coil face.
Old 05-12-2012, 08:56 AM   #3
Rewards Points: 292
What I'm really trying to get a handle on has to do with the issue of CFM, i.e., setting airflow < or > 400/ton. While it has been stated that > 400 will result in higher efficiency, the supply air is higher in temperature. Intuitively, I would think that moving more air mixing with room air (even at a higher temp), would result in a shorter run time (less electricity = higher SEER).
An example of this would be, when I enter my sun-baked car. I usually run the a/c at 1 or 2 (airflow). Normally, this would take a long time to cool things off. Turning the fan up to 3 will shorten the cooling time. If, as I assume that auto a/c's run at a single stage, the airflow temp would be higher even though it feels about as cold (due to high velocity??).
So, I'm trying to nail down how in general a +/- adjustment to airflow would affect cycle time. Comment please.
Not really up on psychrometrics, so can't comment.
Old 05-12-2012, 09:25 AM   #4
Yes,lower cfm equals longer run times. An AC removes X BTU's per hour with some being temp and some being moisture. A thermostat only reacts to temp. With that said the extra electric used for longer run run times is offset by the thermostat being able to set 3-4 degrees higher and have the same human comfort because the humidity level is lower.
Old 05-12-2012, 11:21 AM   #5
Rewards Points: 292
Thanks, that was what I was looking for (and confirms my suspicion). If I can increase my latent cooling and comfort level, I'll be happy. Energy costs in past (hot) summers has not been excessive, so a little more won't hurt.
Old 05-12-2012, 12:53 PM   #6
An old Tradesmen
Rewards Points: 6,140
Unfortunately its not as cut and dry as we might like it to be. While a higher air flow rate will lower house temp quicker. It will also remove less moisture from the air, causing you to feel warmer.
74 at 46%RH feels just as cool as 72 at 50%RH. But running higher CFM through your coil, you could end up with 70 at 54%RH.
You need to see if the lower air flow will dehumidify the house enough that you feel just as comfortable at a higher temp then you do at the higher air flow.
Your A/C will get a higher SEER with a higher air flow and a room temp of 80F. Then it will with a lower air flow and a room temp of 74F. But A/C is about comfort, so chose which one you want. high efficiency, or comfort.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
