Themostat Trim Piece - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 10:28 PM   #1
Themostat trim piece
The thermostat I replaced is smaller than the original. Therefore, the wallpaper doesn't cover fully cover the area surrounding the new thermostat. Do they make a base plate to cover this? Almost like a trim piece. What is this product called?
pomelo is offline   Reply With Quote
Old 02-07-2010, 11:51 PM   #2
An old Tradesmen
Rewards Points: 6,962
A deco plate.
Old 02-08-2010, 03:20 AM   #3
If it's Honeywell or White Rodgers they do have them.
If not get a small piece of plastic about one and and half longer and wider than the stat.
Should be available at a local HD or Lowes. Can only find pieces too large?
Get the smallest of the large pieces you can. Use a metal rule to measure and score to size with a sharp implement.
Get clear plastic if you cant match stat color. Paint it the color of the stat
or go here
stwww.amazon.com › Tools & Home ImprovementPlumbing at.
hvaclover is offline   Reply With Quote
Old 02-08-2010, 07:20 AM   #4
It's a Honeywell Visionpro. Does Home Depot or Lowes sell them, or do I need to purchase one online? I also have a Johnstone and Baker Bros. in my area.
Old 02-08-2010, 01:48 PM   #5
Johnstone.
Old 02-09-2010, 05:48 PM   #6
hvaclover
Do you know the Johnstone sku number? What should I ask for? A thermostat wall plate cover???
Old 02-09-2010, 07:13 PM   #7
Houston204's Avatar
Rewards Points: 556
I think it's the Honeywell 50002883-001 backplate. I get them at Johnson Supply, but I'm sure that Johnstone has them as well. I use them on the TH60o0 series and the TH5000 series.
Not sure that it supports the TH8000 series. The measurements seem to indicate that it would, but nothing on any site verifies this.
  • Includes 2 cover plates that can be mounted directly on a standard junction box
  • Covers marks on wall or when new thermostat does not completely cover old thermostat wall imprint
  • Medium Cover Plate 5 in. high, 6 7/8 in. wide. Large Cover Plate 6 in. high, 8 5/16 in. wide.
  • Color premier white
Houston204 is offline   Reply With Quote
Old 02-09-2010, 09:04 PM   #8
Thanks Houston204,
I found a plate that works with the honewell visionpro. I'll see if Johnstone carries it. If not, I'll purchase the one you recommended. I should be able to make it work. It looks like the difference is the hole placement.
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 06:00 PM
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 10:32 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Horizontal trim piece around home audiowizard Carpentry 5 07-07-2008 04:23 PM
