Themostat Digital Thermometer - HVAC - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 08:20 AM   #1
Rewards Points: 204
Themostat digital thermometer
I have a Bryant Evolution system and the thermostat is this one...
See where it tells you the outside Temp (upper left corner), mine says sens error. I went out to my AC and pulled the side cover off and found two wires frayed. They are wired nutted to a green and black wire coming from the ac panel. I attached the wires together and nothing. I then put each one on the metal casing (ground) and it registered a temp and then went back to sens error. Any ideas how to get this working?
I don't know what these wires are supposed to attach to.
Thanks.
Abs777 is offline   Reply With Quote
Old 04-15-2010, 05:21 PM   #2
An old Tradesmen
Rewards Points: 7,268
Probably need a new sensor.
Although grounding them like you did wasn't the best thing for that thermostat.
Old 04-16-2010, 06:08 AM   #3
Rewards Points: 204
Where is the sensor located?
Old 04-16-2010, 06:13 AM   #4
An old Tradesmen
I forget its exact location in the outdoor unit. Follow the wires that are frayed and they will go to the sensor.
Old 04-16-2010, 08:29 AM   #5
Rewards Points: 204
That is the weird part. The wires are wire-nutted to a green and a black wire. Like this in the attachment.
Would these wires go to sensor and the sensor is missing?
Old 04-16-2010, 12:39 PM   #6
An old Tradesmen
Its possible it got removed because it shorted out.
Old 04-16-2010, 12:44 PM   #7
Rewards Points: 204
It did work when I first moved in last year. Then all of a sudden it started saying sensor error, then it worked a while, then sensor error and stayed that way. The wires ran from the inside of the AC unit down through the bottom of the unit. Maybe I hit the sensor with the weedeater. Are the sensors usually on the exterior of the unit?
Old 04-16-2010, 12:48 PM   #8
If you have a VOM or DVM, and if Bryant will tell you the resistance values of their sensor for different temps, you can check the sensor.
Alternately you can buy a resistor from Radio Shack with a value within the range Bryant told you, and hook it to your thermostat and confirm that the 'stat has not been damaged.
If they use a diode instead of a thermistor to sense temp. the tests become somewhat more complicated.
Old 04-19-2010, 08:35 PM   #9
Thanks.
you may have a broke wire detach it from both ends and tie it together on one end and use a wire tracer if you dont get anything on the tracer you may have to run a new wire and its always usefull if you need say 2 wire or 5 wire to run 5 insted of 2 or 8 insted 5 that way you have a extra wire in case one brakes down the road
andrewmiles is offline   Reply With Quote
