TH8320/Gas Furnace/Heat Pump - Electric Bills Have Gone Way Up - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 06:18 AM   #1
Rewards Points: 32
I just recently purchased two Honeywell TH8320 thermostats for a house my wife and I just recently moved into. After install I thought everything was working great, but my last two electric bills have been ridiculously high. I have a gas furnace so I found this really strange. The furnace is a GMP100-5 (propane) and I have a Goodman split system heat pump. One unit runs the first floor and basement, while the other runs the 2nd floor. The attic furnace (heats 2nd floor) is Goodman model AR42-1.
The thermostat had been on the factory settings. Thinking that was my problem, last night I tried to play around with the settings in the advanced setup. I awoke to a VERY cold house. I just did a reset on the thermostat to get it back to the original settings.
The wiring on the both thermostats is as follows. There are orange and black wires too, but those are not hooked up.
RC/R-jumper (from factory)
R-red
W-white
Y-yellow
G-green
C-blue
Can anyone help me with the advanced settings for the thermostat or tell me what else might be wrong? Do I need to have 170 set to 7? 180 set to 0? Thanks in advance – I really need the help.
ZMonet is offline   Reply With Quote
Old 02-02-2010, 07:18 AM   #2
An old Tradesmen
Rewards Points: 7,414
Well. Its wired wrong. You need to connect the O to the orange wire.
170-7
You shouldn't have option 180 after you set 170 to 7.
190-0
210-0
Old 02-02-2010, 07:42 AM   #3
Rewards Points: 32
Wow, I really did screw this up. I've included some pics.
The way the upstairs thermostat was. I apologize for the lack of focus, but the camera would not focus even on manual.
The way the wiring is right now.
Old 02-02-2010, 10:50 AM   #4
Rewards Points: 32
Beenthere -- Thanks. I don't have a 210, but that looks like it is applicable only for when you have an outside sensor. I have now hooked the downstairs thermostat as follows:
R-red
O/B-orange
Y-Yellow
G-green
C-blue
Aux-white
The orange was rolled up with the black and brown wires, so I had to unravel it and then take off some of the plastic to connect it. I set 170 to 7; 190 to 0 and 200(auxiliary heat) to 0 (electric). The furnace comes on but I don't see flames. I'm not sure how I test it to make sure everything is operating smoothly. I've about given up and called my local HVAC people, but they want around $350 ($89 for diagnostic+$120 per thermostat) to look at it.
UPDATE: The furnace wouldn't fire, so I set it back to:
R-red
O/B-white
Y-Yellow
G-green
C-blue
I also set 170 back to 1. These are the exact wires that were connected on the old thermostat. The furnace is now running on gas again.
On the upstairs unit I have the following:
R-red
O/B-orange
Y-Yellow
G-green
C-blue
Aux-white
E-black
This is now the same as what was hoked up on the old thermostat (I previously didn't have the black and orange hooked up). I see that if I raise the temp. two degrees, auxiliary mode comes on. Is this normal? I've set 170 to 7 on this unit.
Does any of this sound right or am I totally lost? I feel like the latter.
Old 02-02-2010, 01:49 PM   #5
An old Tradesmen
Why would you do that if your have a LP furnace, and not electric?
It should be set to 1, fossil fuel.
Good thing the furnace didn't light. Since that could damage your compressor.
You might want to see what wires are connected where at the furnace and heat pump to make sure where they should connect on the thermostat.
Most likely the orange wire to the O terminal was correct. And teh furnace not lighting is unrelated.
But your changing set up parameters to setting that WILL harm your heat pump.
Old 02-03-2010, 06:59 AM   #6
Rewards Points: 32
Since my house is heating, let me ask my question a different way. For a liquid propane system, is there any way I could incorrectly hook up the thermostat that would make it so that my heating bill would double? It went from $350/month to around $700/month.
Old 02-03-2010, 07:33 AM   #7
An old Tradesmen
Yep.
If that black and orange were touching in the wall.
You could have had the A/C and heating running at the same time.
Also, if the furnace is set to too many cycles per hour, it will use more fuel.
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Better for heat pump or electric coil/strip? Lori 48616 HVAC 5 09-05-2008 02:28 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
