Testing Reversing Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 12:36 AM   #1
Rewards Points: 150
testing reversing valve
Hey, I have an old Goodman that had a blown transformer. Change the transformer - now inside unit runs fine but the outside unit will not go into ac mode. I replaced the board with no luck. When I remove the wires and test the reversing valve it reads dead short, but tested another unit and same thing. I removed all wires and plugged the reversing valve to red and black (30 V) and did not hear the famous hissing. I even took a hammer and tapped it.
My question is shouldn’t I hear the hissing just by putting 30V to it? Should it read a dead short. If it is not the reversing valve, what else could it be. When I hook up all wire except the orange it works great but in heat mode.
Any clues? Thanks again!
wetbar is offline   Reply With Quote
Old 05-26-2011, 01:21 AM   #2
JJboy's Avatar
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 05-26-2011, 07:43 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
you may have ruined the valve since you hit it with a hammer.....doesnt matter how hard you hit it. It may stick now. Often the coil that controls the valve can be removed. The noise you expected to hear would not be heard without the unit running.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
