Old 10-05-2012, 02:46 PM   #1
biggles's Avatar
testing natural gas header line
with compressed air or nitro what is typical pressure to hold and for and for how long...thanks
Old 10-05-2012, 02:54 PM   #2
Air is what is used to test most gas lines. Nitrogen doesn't come into play until you have very large lines. Code minimum here is 15psig for 15 minutes, but yours may vary. Check with your local authority having jurisdiction.
hvac benny is offline   Reply With Quote
Old 10-05-2012, 06:48 PM   #3
inside house line...3lbs for 15.min....outside service line 90lbs for 10 min... here in my area of pa..ben sr
Old 10-05-2012, 07:48 PM   #4
wow.... Manitoba is 15-20 lbs for 15 min
carmon is offline   Reply With Quote
Old 10-05-2012, 07:56 PM   #5
Code minimum is 15/15 across Canada, as I'm sure you are aware. It seems that every inspector in BC wants 30psig. We test the service line to the meter at 100psig for 10min., but that's for a working pressure of 60 or 80 psig, depending on area.
The Following 2 Users Say Thank You to hvac benny For This Useful Post:
ben's plumbing (10-05-2012), carmon (10-05-2012)
Our 1st home, found a buried natural gas line Turbogus Plumbing 7 09-25-2012 06:26 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 03:29 PM
Can cast-iron natural gas line be changed to copper? klein General Discussion 19 07-25-2010 08:14 PM
cutting natural gas line ? slawek16506 Plumbing 3 09-06-2009 04:01 PM
Running a natural gas line Roger General Discussion 2 02-27-2009 08:42 AM
