-   -   testing natural gas header line (http://www.diychatroom.com/f17/testing-natural-gas-header-line-159068/)
biggles 10-05-2012 02:46 PM
with compressed air or nitro what is typical pressure to hold and for and for how long...thanks
hvac benny 10-05-2012 02:54 PM
Air is what is used to test most gas lines. Nitrogen doesn't come into play until you have very large lines. Code minimum here is 15psig for 15 minutes, but yours may vary. Check with your local authority having jurisdiction.
ben's plumbing 10-05-2012 06:48 PM
inside house line...3lbs for 15.min....outside service line 90lbs for 10 min... here in my area of pa..ben sr
carmon 10-05-2012 07:48 PM
wow.... Manitoba is 15-20 lbs for 15 min
hvac benny 10-05-2012 07:56 PM
Code minimum is 15/15 across Canada, as I'm sure you are aware. It seems that every inspector in BC wants 30psig. We test the service line to the meter at 100psig for 10min., but that's for a working pressure of 60 or 80 psig, depending on area.
