Testing Heating Element - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 12:52 PM   #1
Testing heating element
My heater is inop. Electric and above bathroom. Thermostat seems ok and calling for heat as it triggers both switches and sending 240 power to elements. I put an amp meter on wire from switch to element and didn't read any draw but line was energized. Appears to be two elements. How would I test them? I was able to put camera up there to take photo. But almost no room at all to pull the element. Blower and acoil in front and can't get visual on elements. Seems odd that both elements would be inop or maybe one had failed earlier. Is there any other test I can do before I pull apart.
Joelw2 is offline   Reply With Quote
Old 01-10-2011, 01:41 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
you will have to use an ohmmeter to check it
hardwareman is offline   Reply With Quote
Old 01-10-2011, 02:56 PM   #3
Thank you. Couple questions. How would i know what a good ohm and bad ohm reading was. Also would i assume I would have to disconnect the power from those connections to get a proper reading?
Old 01-10-2011, 03:03 PM   #4
Experienced
Jackofall1's Avatar
You may be able to look-up the rated resistance on the net, or call the company that manufactures the heater and you will have to isolate the heater coil to test it.
Old 01-10-2011, 05:39 PM   #5
If you have 240 volts at each coil and no amp draw then the coils, or a fuse link attached to them, are shot.
Heating element install ???? 50juan HVAC 1 05-18-2010 04:31 AM
Small heating element mgeno216 Electrical 6 03-20-2010 01:22 PM
Tile flooring over heating element Woodchucker Flooring 4 01-21-2009 11:14 AM
Proper Voltage for small Nichrome heating element. Dacr0n Electrical 8 01-19-2009 11:30 AM
electric dryer heating element gooch Appliances 2 03-27-2007 09:31 PM
