Test Time For Pros And DIYer... - HVAC - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 08:21 PM   #1
Test time for Pros and DIYer...
Ques: Evacuation to well below 200 microns is:
A] Desirable and even even mandatory to remove all moisture.
B]The lowest level system should be pumped down to because ..(describe the changes that would be detrimental to the sealed system)
C] What is an evacuation?
Winner gets a No-Prize.
hvaclover is offline   Reply With Quote
Old 04-07-2009, 09:13 PM   #2
Idiot Emeritus
Rewards Points: 1,492
It's been a while since I've actually done refrigeration work, but if the system isn't brought to a sufficient vacuum, it won't boil all the water out, and some non-condensible gasses will be left in.
I'll go with 'A'. 200 microns sounds familiar, but I could be way off.
I don't think a closed system could be pulled into enough of a vacuum to cause damage, in fact, it must be pulled into a pretty deep vacuum before it can be charged with refrigerant.
Leaving water and other icky stuff in it will dramatically shorten its life.
Rob
micromind is offline   Reply With Quote
Old 04-07-2009, 09:43 PM   #3
An old Tradesmen
Rewards Points: 6,112
You could of made it a tough question.
Old 04-07-2009, 10:00 PM   #4
Sarcasm from the Master?
Give us your slant then, Been.
Old 04-07-2009, 10:03 PM   #5
HVAC / Plumbing
shouldn't C be , re-claim, re- cycle ???
I could be wrong but,
I thought evacuate was when you took all the refrigerant of someone's unit, took it home re- cycled it & put it in someone elses unit or, is that re- claim ? O' well who cares as long as it's cooling when you leave
kenmac is offline   Reply With Quote
Old 04-07-2009, 10:08 PM   #6
An old Tradesmen
B.
The older mineral oils had wax/parrafin that could be separated.
Its not a worry with new mineral oil anymore.
Newer mineral oil, isn't effected until about 50 microns.
There was a big thread about this 6 or more months ago, at that other place.
I think Roby from National Refrigerants also participated in it.
As you probably know. He is a very open and straight forward guy, about myth and fact for refrigerants and oils.
Sort of like Andy Schoen for TXVs.
Old 04-07-2009, 10:14 PM   #7
I'll give it to you but the source i got it from is my latest SAM supplement and it says to exceed 200microns. So as long as you don't bust 200 your ok.
Old 04-07-2009, 10:29 PM   #8
An old Tradesmen
Doesn't suprize me.
Lot of resources will play it safe.
Hard to know, what oil that 8 year old unit has in it.
is it safe for 100 microns. or is it older oil, and not safe below 200 microns.
Most manufacturers, are still only recomending 500 to 400 microns for R410A systems.
York still sys to replace the line set when going from R22 to R410A.
Carrier says, just flush with Nitrogen.
In the field, it comes down to best practice and common sense for the job your on.
PS: Did you see the discussion about vacuuming water from underneath oil.
Old 04-07-2009, 10:42 PM   #9
Doesn't suprize me.
Nope didn't catch that. But your other points explain why there is such a regional difference in service practices.
Carrier made the new with their nitro purge article.
Be real interesting to see how all this new service techniques become bastardized over the coming years.
Old 04-07-2009, 10:51 PM   #10
An old Tradesmen
The guy in Florida. (you know who I mean)
They been doing nitro purges since 99 or so. And haven't had a failure of any type linked to purging instead of using a checmical flush.
Funny thing is.
In refrigeration. We been using POE oil since the early 90s(before anyone heard of R410A).
Only time any real problem with a conversion. Is if the evap was oil logged. Then the MO to POE mix is too much.
Old 04-07-2009, 11:06 PM   #11
Funny thing is.
AAHHhhh... the good old refer days. Got out of that end of hvac when an Arab store owner pulled a gun on me..
His out side condenser suddenly and mysteriously disappeared that night.
I don't see any problem with a nitro purge and a good evacuation.
My first ac install was a Weatherking split made by Addison Products. Install instructions called for a back flush of liquid 22 for 15 seconds. Never lost a comp on any of em.
Old 04-07-2009, 11:37 PM   #12
An old Tradesmen
Westinghouse for me.
Purge and time metered the charge on them back in those days.
Old 04-07-2009, 11:42 PM   #13
I still have this old Thermal products automatic charging gizmo. Thing belongs in a museum.
Old 04-08-2009, 05:22 AM   #14
An old Tradesmen
I use to carry a 5, and a 10 pound charging cylinder.
Until the mid 80's.
We use to sell R22 for 3 bucks a pound.
Old 04-08-2009, 08:19 AM   #15
Weatherking
I still have old Weatherkings 30 years old running. Efficiency, Oh well Reliability . Liked the RCU unit with the suction accumulator.
Answer to A, B, C, does it have anything to do with a bathroom. I know 30 years go ahead and say it.
SULTINI is offline   Reply With Quote
Most versatile drill/system for typical DIYer tigereye Tools 16 03-22-2009 10:55 AM
Building firepit need advice for first time DIY'er... jaysen Landscaping & Lawn Care 29 05-08-2008 06:27 PM
DIYer? eric s Painting 1 09-30-2006 10:28 AM
