Terminology Help - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 10:43 AM   #1
JPM
Bill Traver
Rewards Points: 101
Terminology Help
I need some help with terminology so I can find a local supply of parts for a very old gas wall-mount furnace.
I need to eliminate some vibration "clanking" when the fan turns on...the riser that it is mounted to shakes a little and when I secure it with my hand, the noise stops.
I am looking to change out the very old vibration dampening things (almost like washers) that are on the bolts connecting the fan motor to the riser. The bolts look like 1/4 20.
I was also thinking of getting some sort of high temp rubber shim sort of thing to place in the tight spaces between the riser and the back sheet metal and the front metal.
I am not sure how to properly refer to these items when looking on the internet and calling people.
Any help would be appreciated.
Thanks!!
JPM is offline   Reply With Quote
Old 11-17-2011, 11:25 AM   #2
biggles's Avatar
sounds like the rubber gromets are dries out that keep the fan tight so the rattling starts but when you steady it up by touching it....if the fan has a squirrel cage on it check the metal fins for dirt build up could be making it shake....when it starts.... like these #3CC00 availible at your local Grainger http://www.grainger.com/Grainger/wwg...N=0&sst=subset
Old 11-17-2011, 12:06 PM   #3
JPM
Bill Traver
Rewards Points: 101
Gromets ... much better than "those black doo-jiggety thingies"
THANKS for your help .... just need to pull the ones I have off and take a quick run to the local GRAINGER ...
Old 11-17-2011, 12:24 PM   #4
biggles's Avatar
good but check those rounds on the squirrel of the fan....for dirt
Pony Wall/Half Wall & Ledge wall??? How to & Correct Terminology Evil Scotsman Carpentry 0 03-02-2011 07:11 AM
Differences in 2xx voltage appliances? Roy Rowlett Electrical 18 09-18-2009 08:28 AM
no-hub terminology davefoc Plumbing 16 03-16-2009 05:15 PM
need some terminology answers MPIC Roofing/Siding 14 12-16-2008 07:16 AM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 08:04 AM
