Terminals Blown Out - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2014, 03:56 PM   #1
Rewards Points: 150
terminals blown out
What would blow out the terminals on a compressor? This has happen twice about 7 years apart. There was a snow storm, but we never lost power that we can tell. We did not have to set clocks or anything like that. But we heard a noise then lots of hissing and looked outside and saw freon going everywhere. Two of the three terminals have been blown out of the compressor.
Thanks for the help
wetbar is offline   Reply With Quote
Old 02-17-2014, 05:19 PM   #2
An old Tradesmen
Rewards Points: 6,112
A winding to winding short.
Old 02-17-2014, 06:35 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Did it happen on the same machine? If so they probably did not clean it up properly after the first burnout and left acid in the system which pooched this one. Time for a new system or some SERIOUS decontamination.
Old 02-18-2014, 09:43 AM   #4
Rewards Points: 150
no it was a totally new system 7 years ago. Both times it happen in a snow or ice storm
Old 02-18-2014, 06:32 PM   #5
Hvac Pro
yuri's Avatar
very strange. sounds like the wiring outside or in the unit is getting wet or a short and grounding out the unit. if the breaker/fuses are too large or the unit not grounded properly that may be a problem. sounds more like a low voltage ( main supply) to the unit problem to me.
Old 02-18-2014, 06:40 PM   #6
Rewards Points: 150
Here is my theory, When the power flickers the unit cuts off and tries to restart with high head pressure, because it just cut off. Maybe?
Old 02-18-2014, 07:11 PM   #7
An old Tradesmen
If power flickers off. The defrost boards 5 minute delay should prevent the compressor from trying to start until the delay times out.
Old 02-18-2014, 08:12 PM   #8
biggles's Avatar
had this Copeland compressor blow the slip Stak-Ons off coupe of times,had to sand the terminals clean and get straight in compressor slips.they have to go on with a niddle nose and be tight with no wire tension within the box... pieces of cut armaflex to keep wires from bouncing around straight AC here no HP...
Blown Insulation vs Blown Fiberglass DRILLINDK Insulation 7 12-18-2012 11:46 PM
batt insulation and blown in langless28 Insulation 14 11-06-2012 09:55 PM
Blown in insulation question? El Gringo Insulation 2 11-11-2011 12:20 AM
Blown insulation Xtreme_99 General DIY Discussions 1 01-05-2009 06:56 AM
Wago terminals for residential line-voltage connections BigJimmy Electrical 3 05-22-2008 02:27 PM
