Terminal Function Of TB1540E-G - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 12:37 PM   #1
Terminal Function of TB1540E-G
I have a SECO TB1540E-G that has a brown wire connected to Terminal E. The thermostat controls an electric A/C unit and a gas furnace. Does someone know what function Terminal E controls? I need to know so I can properly connect a new programmable thermostat.
Thank you for any assistance.
B52 Nav Flyer is offline   Reply With Quote
Old 09-14-2012, 01:53 PM   #2
Willing to listen
Rewards Points: 219
E is usually for Emergency heat...back-up heat source, for example in a heat pump system to bring on the electric strip heat if the compressor heat can not keep up with demand. W is usually primary heat.
Can you follow the wire to the furnace and see what it is currently attached to on the furnace control board?
Done That is offline   Reply With Quote
Old 09-14-2012, 02:04 PM   #3
Thank you
I'll see if I can trace the wire this weekend.
Tags
tb1540e-g thermostat
Fan Relay Wiring, Purpose of #5 terminal??? Ralph III HVAC 4 03-30-2012 10:53 PM
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 09:04 PM
Heat but no A/C with new thermostat myqhenry HVAC 15 05-30-2011 11:53 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
"G" terminal on Tstats javan HVAC 8 02-08-2009 03:16 PM
