-   -   Terminal Function of TB1540E-G (http://www.diychatroom.com/f17/terminal-function-tb1540e-g-156791/)
B52 Nav Flyer 09-14-2012 12:37 PM
I have a SECO TB1540E-G that has a brown wire connected to Terminal E. The thermostat controls an electric A/C unit and a gas furnace. Does someone know what function Terminal E controls? I need to know so I can properly connect a new programmable thermostat.
Thank you for any assistance.
Done That 09-14-2012 01:53 PM
E is usually for Emergency heat...back-up heat source, for example in a heat pump system to bring on the electric strip heat if the compressor heat can not keep up with demand. W is usually primary heat.
Can you follow the wire to the furnace and see what it is currently attached to on the furnace control board?
B52 Nav Flyer 09-14-2012 02:04 PM
Thank you
I'll see if I can trace the wire this weekend.
