Tennis Ball Went Down PVC Tubing For Furnace Vent. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 07:33 PM   #1
Tennis ball went down PVC tubing for furnace vent.
My son was throwing a ball against the house & it went in/down the PVC vent. What should we do? Can we disconnect a joint to find the ball? Do we need to call our furnace/AC company? My husband thinks it went down the fresh air intake tube.
Appleton is offline   Reply With Quote
Old 08-31-2012, 07:50 PM   #2
Rewards Points: 582
if installed right those lines slope towards furnace....don't know what fittings were used or if ball will go through them..... ..look in line with light ..if you can'tsee ball ..call furnace company...
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (08-31-2012)
Old 08-31-2012, 08:15 PM   #3
Guessing it has to be a 3" vent for a tennis ball to fit in. Should have rolled all the way to the furnace. Disassemble the pipe at the furnace and check. If it's not there run a snake through the pipe to push it out.
The Following User Says Thank You to Marty S. For This Useful Post:
Old 08-31-2012, 08:55 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Call the yankees or cubs and get him signed up if he can accidently hit a ball down that pipe!
If the ball made it down towards the furnace chances are the pipe comes out of furnace as a 2" then transituions to a 3" pipe,id start looking towards the transition area first.
Id see if the pipe will come off furnace easy enough,you might need to cut the pipe just above furnace to remove it then use a fernco or no hub coupling to join it back together.
and Id also install a 90 degree fitting on outside of house where pipe comes out
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (09-01-2012)
Old 08-31-2012, 10:38 PM   #5
try sucking it out with a shop vac
Old 08-31-2012, 11:09 PM   #6
plummen's Avatar
Unless it fits in the pipe pretty closely and youve got a really big shop vac Im not sure that would work
ben's plumbing (09-02-2012)
Old 09-01-2012, 03:33 AM   #7
biggles's Avatar
borrow a electrical snake from somebody and attack it from the furnace end ,even a lenght of soild wire can't be that tight will roll back out...
Old 09-02-2012, 01:26 PM   #8
Rewards Points: 242
i removed a tennis ball from a 2 in flue. homeowners kid seen a pipe
and stuck the ball in. was only in a few inches as it was a little tight.
i took fitting off of furnace and used nitrogyn and shot it out. if 3in.
you might be able to use compress air or the exhaust of the shop vac.
hvac instructor is offline   Reply With Quote
The Following 2 Users Say Thank You to hvac instructor For This Useful Post:
ben's plumbing (09-02-2012), plummen (09-02-2012)
few vent questions diy001 Plumbing 0 05-22-2011 08:47 AM
Dryer vent installation Wiscbldr Building & Construction 3 05-04-2011 03:14 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Ooops Situation - ball meets vent pixelsherpa General DIY Discussions 4 04-01-2009 11:48 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
