Tempstar Pilot Not Lighting After Draft Inducer Replacement - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2009, 06:30 PM   #16
You would not get gas at the pilot as you earlier stated were that true.
hvaclover is offline   Reply With Quote
Old 03-26-2009, 06:49 PM   #17
Might be time to call a pro.
You an engineer by any chance?
Old 03-26-2009, 07:32 PM   #18
HVAC / Plumbing
sounds like it's the ignitor or the electrical portion that feeds power to the ignitor..Like hvclover said .If it were the vaccum/pressure switch you wouldn't have gotten pilot gas.....I hate those dumb valves..Over the years honeywell has made several changes to the valve ..It's still dumb
kenmac is offline   Reply With Quote
Old 03-26-2009, 09:27 PM   #19
as seen on tv
Rewards Points: 150
The pressure switch is functioning ok since it closes when the inducer goes on. When the switch is closed I read 29V across it. When a switch is closed you should not read source voltage
qbert is offline   Reply With Quote
Old 03-26-2009, 10:13 PM   #20
HVAC / Plumbing
You don't read voltage across a closed switch. You read voltage across an open switch. If it's closed you can read from switch to ground
Old 03-27-2009, 06:34 AM   #21
An old Tradesmen
Rewards Points: 6,464
That seems to confuse a lot of techs also.
Old 03-27-2009, 09:22 AM   #22
I am and the electronics involved in this is kindergarten stuff.
Alright so this is also confusing me...when the switch is closed I get continuity across it and also a 29v drop across it. Bad switch...I don't get it? Please someone confirm if this is a crazy switch.
Kdavid is offline   Reply With Quote
Old 03-27-2009, 09:52 AM   #23
First law of electricity I learned was voltage takes the least line of resistance. In this case the closed switch is that line of least resistance, your meter the higher path. Can't have both.
Old 03-27-2009, 09:57 AM   #24
Cool...I got it.
When I pull the wires off the switch it reads open with the induction motor on and read open with the motor off. Is it supposed to do that?
Old 03-27-2009, 10:05 AM   #25
HVAC / Plumbing
How can you be confused ??....'' this is kindergarten stuff "
Old 03-27-2009, 10:05 AM   #26
Cool...I got it.
You said this was kindergarten stuff.
I am beginning to think you are deliberately posting misleading info. The inducer would have to be running to check continuity and you did not say that the wire were disconnected. You would have blown the fuse in your meter checking that system live.
Five days no heat.
I am beginning to smell a troll.
Old 03-27-2009, 10:11 AM   #27
HVAC / Plumbing
Must have flunked !
Old 03-27-2009, 10:15 AM   #28
It's true no heat since Sunday. The house never got below 49 and I travel a lot so hasn't been a big deal. It's supposed to be 63 today and that is good news. It actually feels colder inside and outside.
Gents, I deal with high speed surface mount electronics hence my kindergarten comment. I still appreciate your help. The only reason I didn't call a pro is because I can get all these parts on Ebay for 1/10th of what a pro would charge me and I could go without heat for a while.
So please help me out man.
I checked the pressure switch with its wires plugged in and not plugged in.
With the wires plugged in:
The switch closes when the induction motor turns on and is open when the induction motor is off.
With wires pulled out:
The pressure switch is open all the time.
Old 03-27-2009, 10:15 AM   #29
Must have flunked !
Ken you know how some pros come here as impostors just to stir up crap
and then crow about it on what ever pro site they come from.
This gent has all the ear marks of a troll. You don't goof up that many readings ...
Old 03-27-2009, 10:22 AM   #30
Haha you got me!!!! I love the word goof.
What have I goofed up?
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 09:38 AM
Draft Inducer question hvachelp HVAC 3 06-17-2008 05:40 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 04:42 PM
