Hello,
furnace: Tempstar NUG9075FGB1 about 13 years old
smart valve: SV9500M 2674
The draft inducer broke so I ordered a new one. The furnace has been off for four days as I was waiting for the new draft inducer to come in and install it.
So I installed it...
I go through the sequence of turning the furnace back on and the pilot won't light. The draft inducer starts, but that's where it ends. No spark or glowing from the igniter.
So I take the cover off to the pilot chamber...
When I start the furnace I can hear the pilot gas coming out after the draft inducer starts. So when I light the pilot manually and put the cover on quickly the flame goes out as if there was too much of a draft or not enough oxygen.
So my question is...is the igniter supposed to glow to keep the flame going or does it just spark to light it once? If it's supposed to be glowing then that's my problem, but either way I don't see it spark or glow. I'm going to test it with an ohm meter when I get home.
So the furnace has been off for four days and all of a sudden something else is broken...what the hell.
Thanks for your time,
Dave
