Tempstar Issue With Cooling Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2008, 08:45 PM   #1
Tempstar issue with cooling cycle
Hey guys I have an odd question. Brand new tempstar furnace when the AC kicks on the blower seems to prepurge then an audible click is heard blower goes off and click coninues intermittently almost like the igniter or a relay then the blower comes on and cooling begins. This doesn't seem right to me and is quite frankly very annoying. I feel as though it is trying to begin a heating cycle could this be my thermostat or does this 90 plus furnace just always go through prepurge before the blower starts. Am I hurting my new furnace? Thanks for the help
Teddy1731 is offline   Reply With Quote
Old 07-08-2008, 09:24 AM   #2
Doesnt sound right. Try shutting off your thermostat and using only the fan switch on/off. Does the same clicking occur then? If so, the problem is more than likely in your furnace. It should NOT go into prepurge before the fan kicks on in cooling mode. Maybe a loose connection at your board or possibly a bad relay on the board.
statman is offline   Reply With Quote
Old 07-08-2008, 11:15 AM   #3
There is no clicking in fan only mode. Sequence of operation is as follows. Fan is on all the time to circulate air, thermostat to cooling mode, fan stops one clickis heard and fan comes on at higher speed. then 20 sec s apart two clicks are heard with no change in fan speed or operation I guess is this normal.
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 01:13 AM
Geothermal cooling loop help stuartm HVAC 2 09-29-2008 11:18 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 02:10 PM
Transformer Help chcustom Electrical 28 12-10-2007 11:40 PM
Gurgling noises in lines after cooling cycle mjb HVAC 2 07-23-2007 10:48 AM
