Tempstar Furnace Is Rumbling When Burner Is Off ?? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 08:20 AM   #1
Tempstar furnace is rumbling when burner is off ??
Hello forum,
I have a 1996 Tempstar gas furnace at home that is rumbling laudly when its burner goes off. When it gets colder and the burner comes on, it sound and work okay. It's fan is working all the time regardless of burner being off or on. I googled a bit and found an answer saying that in this case I need to reduce the gas supply to the pilot. I opened the front door and couldn't find any tap, screw or anything that could adjust the gas flow to the pilot. Does anyone have an idea what I have to do? If it helps, I can take some picture of the components and post it. Thanks in advance.
digitop is offline   Reply With Quote
Old 12-07-2009, 09:30 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
"It's fan is working all the time regardless of burner being off or on."
in this case, the first thing i would check is the thermostat fan setting. be SURE it's on "AUTO"!
also, some furnaces have another fan on/off button on the front or inside to turn it on and off. this may be in the wrong position as well.
DM
Old 12-07-2009, 06:39 PM   #3
Hi DangerMouse,
Thanks for reply. The thermostat setting for the fan is on Auto but this doesn't change anything, it's running all the time. I also couldn't find any switch or anything inside the furnace itself except there's a ON/OFF button on some component which is on the way of gas supply line as you see on the first attached picture (File 061.JPG). I post a few picture here hopefully this could help. Thanks
Tempstar furnace is rumbling when burner is off ??-061.jpg   Tempstar furnace is rumbling when burner is off ??-021.jpg   Tempstar furnace is rumbling when burner is off ??-051.jpg   Tempstar furnace is rumbling when burner is off ??-031.jpg   Tempstar furnace is rumbling when burner is off ??-121.jpg
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Rumbling and Smelly Burner Jay_NH HVAC 7 08-14-2009 09:18 PM
Natural gas forced furnace - Burner shuts off prematurely scooter100 HVAC 9 01-25-2009 11:46 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
