Old 02-25-2010, 03:03 PM   #1
Tempstar Furnace
Hello Everyone,
I have a new Tempstar furnace. Is there a way to increase the strength in which it blows out the air? Seems to be coming out weak.
Also, I have an digital thermostat. How does it know if it reached the temperature I set it to? Does it have a thermometer inside?
Thanks in advance.
llckll is offline   Reply With Quote
Old 02-25-2010, 06:34 PM   #2
An old Tradesmen
Tempstar Furnace
Yes. It has an internal temp sensor.
Old 02-25-2010, 06:43 PM   #3
Tempstar Furnace
What's wrong with the instal of the furnace?
Old 02-25-2010, 06:59 PM   #4
Tempstar Furnace
Yes I did. Please enlighten me.
Old 02-25-2010, 07:01 PM   #5
hvaclover's Avatar
Tempstar Furnace
Originally Posted by plummen View Post
that depends on whether you paid someone to do the work
llckll, just stand back and take a good long look at that furnace and ask yourself if you were a Pro hvac tech, would you be proud of that kind of work if you had installed it?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 02-25-2010, 07:03 PM   #6
Tempstar Furnace
How would you have installed it differently so that I know how it should have been done properly.
Old 02-25-2010, 07:06 PM   #7
Tempstar Furnace
Originally Posted by hvaclover View Post
Wow
Did Ray Charles install that job
Looks new so I hope you still have the paper work for the furnace and thermostat.
They have a trouble shooting page in each owners manual for the questions you asked.
I do have the paper work. But why are you asking?
Just trying to understand other professionals point of view.
Old 02-25-2010, 07:18 PM   #8
Tempstar Furnace
I just want to know how others would have installed it. From what I understand, he just swapped out the old one and put in the new.
Old 02-25-2010, 07:28 PM   #9
hvaclover's Avatar
Tempstar Furnace
Ok just having a little fun on you. To put it simply the job is very sloppy.
All that is holding your new furnace to the old duct work is a lot of foil tape.
A transition made from sheet metal should have been fabricated to go from the furnace to the old duct work.
That foil tape is just covering a lot mistakes.
The electrical hook up is all old conduit. That looks bad and can be a problem
later on.
Was this job installed with a heating permit?
Old 02-25-2010, 07:32 PM   #10
Tempstar Furnace
later on.
Little fun is ok. I'm pretty sure the guy didn't have a permit. I'll go check to see if it's only foil tape holding it up. Might be screws too.
I guess it is what it is right now...
Old 02-25-2010, 07:42 PM   #11
hvaclover's Avatar
Tempstar Furnace
If no permit was pulled the inspector is gonna rip the installer a new one.
Old 02-25-2010, 08:32 PM   #12
retired elect/hvac/plumb
plummen's Avatar
Tempstar Furnace
Ive got no problem with duct tape when properly used,but it seems to me that this guy didnt have a clue about what he was doing when installing your furnace.
The sheetmetal work done to transition the new furnace and coil is just beyond half ass ,the cased coil doesnt even match the furnace.back of furnace looks like it was beaten with a large hammer .crooked improperly bent not supported conduit................. the guy should be beaten with his own tools if he charges for this kind of work!
Normally I dont drink,but I think im ready for one!
plummen is offline   Reply With Quote
Old 02-25-2010, 08:34 PM   #13
Tempstar Furnace
Ok, going back to my original question. Do these new furnaces have a dial to increase the power or air being blown?
Old 02-25-2010, 09:17 PM   #14
Tempstar Furnace
They either have dip switches on the contol board that can be changed or you swap blower wires. How to do each is in your manual that came with the furnace.
Old 02-26-2010, 09:29 AM   #15
30 year tech
hvac122's Avatar
Tempstar Furnace
Can you show pics from the front side of the furnace? Dosn't look like there is much space in fron of it to service. Here, code is 30" minimum. How is it vented?
As others have said pretty shoddy looking job.
hvac122 is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Tempstar furnace is rumbling when burner is off ?? digitop HVAC 2 12-07-2009 06:39 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
