Tempstar Fan Will Not Come On In A/c Mode - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 08:35 AM   #1
Tempstar fan will not come on in a/c mode
I have a Tempstar PA5542AKA when in A/c mode the condensor and fan comes on but the blower motor will not start. The blower will come on in heat mode and run fine. Is it something in the control board or maybe a sequencer? I never felt that it was putting out enough heat in the winter but all elements seamed to be energized so I left it alone.
scottie9656 is offline   Reply With Quote
Old 04-26-2009, 10:24 AM   #2
HVAC / Plumbing
will it come on if you switch fan on at the t.stat ?
kenmac is offline   Reply With Quote
Old 04-26-2009, 10:35 AM   #3
No it will not come on with the t-sat on fan only
Old 04-26-2009, 10:42 AM   #4
HVAC / Plumbing
Probably the relay on the control board for high speed fan.. You can check with v m
Old 04-26-2009, 11:37 AM   #5
It has 120 volts on all three wires with the unit off.
Old 04-26-2009, 12:27 PM   #6
An old Tradesmen
Rewards Points: 6,592
What wire where you checking from, that all 3 had coltage with teh unit off.
Old 04-26-2009, 02:31 PM   #7
one goes to the blower,one goes to the sequencer, and the one on top goes to the coil.
Old 04-26-2009, 02:44 PM   #8
An old Tradesmen
Ok.
So your checking for voltage on a 220/240 volt motor.
You should read 120 weather or not its receiving a call to run.
The controls only open 1 leg of the 220.
Need to know if its getting 220/240 when the stat is set to fan "on" or the stat is calling for A/C.
Old 04-26-2009, 03:04 PM   #9
no it is not getting 220 to the motor on run or A/C.
Old 04-26-2009, 03:15 PM   #10
An old Tradesmen
Not familar with that blower off the top of my head.
See where the green wire from the stat goes.
That is where your bad/stuck relay sequencer is.
Old 04-26-2009, 03:27 PM   #11
The green wire from the stat actually goes to the control board, then a red wire goes to one of the sequencers would that be it?
Old 04-26-2009, 03:32 PM   #12
An old Tradesmen
Does a wire go directly from the board to the blower.
Old 04-26-2009, 03:50 PM   #13
yes one goes to high speed tap on the blower and the other goes to a sequencer. I have a wiring diagram I will try too send.
Old 04-26-2009, 03:54 PM   #14
An old Tradesmen
The high speed is the one that supplies the second leg for the blower motor in cooling and for fan "on" setting.
Good chance the board is bad.
Old 04-26-2009, 04:08 PM   #15
wher would be the best place to get a new one? It loks like it would be easy to exchange.
GE Electric Dryer won't shut off in auto/high heat mode jktbnelson Appliances 7 01-15-2011 08:39 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
GE Dryer does not shut off in any mode brogrimm Appliances 4 01-30-2009 08:11 PM
fan does not work in "auto" mode on my Lennox Pulse 21 gas furnace OliverMogan HVAC 1 01-22-2009 09:54 AM
