Tempstar Control Module - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2013, 11:16 AM   #1
pss
There was no ignition, the exhaust blower was running continuously and the control module red light was flashing.
After shutting power off for 10 minutes, furnace operation returned to normal. Any suggestions on what would cause the red light to flash continuously. This is a 21 yr old Tempstar.
pss is offline   Reply With Quote
Old 01-17-2013, 12:14 PM   #2
depends on how many flashes....need the model number of furnace.
hvac5646 is offline   Reply With Quote
Old 01-17-2013, 01:01 PM   #3
pss
Model is NULK075DG05. The red light was flashing ~1 every second. I now also notice the paper diag. on the inside of the upper cover is bubbling out in spots and that flame on start shoots out more than normal (rollout). Could the rollout sensor have caused the trip.
Old 01-20-2013, 10:47 AM   #4
pss
Problem resolved. Dirty wire connection (24v) on the control module was preventing the gas valves from opening. After two failed attempts to light, the control module would then start flashing.
ignition control module or spark ignitor issue? agent86 HVAC 2 12-20-2012 08:03 PM
Changing Control Board Questions -- HSI module and AC wire connection humdinger0102 HVAC 7 11-17-2011 12:16 AM
Ignition Control Module Question us215013 HVAC 1 01-06-2010 12:43 PM
I need an ignition control module thehvacguy HVAC 0 12-30-2009 11:42 PM
DIY recommendation for Goodman Control Module (Circuit Board) njwaves HVAC 3 09-26-2009 07:29 AM
