Tempstar Central Air Outdoor Unit LOUD - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2012, 09:21 AM   #1
Rewards Points: 150
Hi Gentleman,
I understand that most central air units are a bit loud by nature but mine has become increasingly louder over the last year. The unit is about 10 years old and by my crude calculations it is a bit undersized and runs for hours at a time in the summer months. My intention is to get it serviced but I was just wondering if there was any obvious things that could be causing the problem. When I moved in 5 years ago the unit was fairly quiet. It is a constant loud hum that only comes from the outdoor unit.
psilva8 is offline   Reply With Quote
Old 05-23-2012, 11:56 AM   #2
Dirt in the fins will make the compressir louder. Might be fine after a good service.
Old 05-23-2012, 01:00 PM   #3
biggles's Avatar
remove the compressor wires tape away and push the contactor in might be a simple condenser fan bearings going free spin both direction hear any grinding..rumbling??....snow sitting on the top of the condenser in the winter.freon is tight have you had it added with a slow leak over the years? oil leaks out in droplets when the freon is exiting compressor might be on it's way out if the condenser fan is quiet?
Old 05-23-2012, 02:24 PM   #4
Rewards Points: 150
Apologies, I'm trying to understand. I haven't noticed any oil like substance anywhere. I will try and free spin the fan to see if I notice anything. I will also clean the fins with a pressure washer although they don't appear dirty. What would pushing the contactor in do?
Old 05-24-2012, 12:16 AM   #5
Never, Never use pressure washer to wash the fins. The fins are soft.
clocert is offline   Reply With Quote
Tempstar Central A/C not cooling JohnRoss HVAC 3 08-31-2011 09:24 PM
Central Vac problem strongbow Electrical 4 10-23-2010 08:49 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
New house, freezing temps, loud popping noises lp61006 Building & Construction 11 02-22-2008 05:36 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
