Tempstar Blower Not Coming On For Heat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 04:42 AM   #16
An old Tradesmen
Rewards Points: 7,414
The limit is only in the burner circuit, it doesn't effect the blower.
Trace where the wires from the blower motor go.
Old 10-12-2012, 07:24 PM   #17
Rewards Points: 610
The "fan limit" control ..IS the control that starts and stops the blower/circulating fan AND shuts off the burner if the fan doesn't start and causes excessive heat in the heat exchanger
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
robertsm (10-18-2012)
Old 10-12-2012, 08:40 PM   #18
An old Tradesmen
Yes. but the pic he drew. he doesn't show the fan side being wired in.
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-12-2012, 08:51 PM   #19
working late again, so won't be able to look into this more until tomorrow (thankfully it's not going to get too cold tonight).
correct on the limit control: there is nothing wired to the fan limit, just on the load limit.
robertsm is offline   Reply With Quote
Old 10-12-2012, 08:53 PM   #20
An old Tradesmen
The blower is connected to a timer/sequencer. Just follow the wires from the blower to their source.
Old 10-12-2012, 09:02 PM   #21
Rewards Points: 582
yep see post #7 ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 10-12-2012, 09:09 PM   #22
beenthere:
Thanks... will do.
RE: the timer/sequencer... would that be this (luckily I have a bunch of pics with me tonight)...
ben sr:
Sorry... just realized that you were asking for a picture of the bottom with the door off. in my sleepy state before I thought you were saying that the bottom door might be off. Anyway, I don't have a pic of that with me, but will get one posted here as soon as I can.
Greatly appreciate the help.
Old 10-12-2012, 09:13 PM   #23
An old Tradesmen
Thats your blowers timer. Its also a limit switch. The Honeywell may be an aux limit.
ben's plumbing (10-13-2012)
Old 10-12-2012, 10:25 PM   #24
Rewards Points: 610
AHA! Get the point! however, that's why I said fan limit OR board. Should have added timed limits..if I had known about them
just like cars ..keep on getting more complicated all the time..but, for better performance...never mind college/university education for your kids ..get them into a trade!!...unless they are obvious Doctor/Lawyer or Engineer material!
BTW you can teach an old dog new tricks
Old 10-13-2012, 06:13 AM   #25
Rewards Points: 582
Originally Posted by robertsm View Post
beenthere:
Thanks... will do.
ben sr:
your problem is in the sequencer.....ben sr
Old 10-13-2012, 05:02 PM   #26
ben sr (or anyone else):
I'm not sure what the sequencer is on my unit. Would that be handled by the Honeywell S8610U control board?
Regarding ben sr's earlier request to see lower panel, here's a pic of the interesting parts:
http://postimage.org/image/yag6oc865/
Side note: as long as I had the unit open I made sure that the exhaust vent pipe was clear.
Old 10-13-2012, 06:34 PM   #27
Rewards Points: 610
as beenthere said the blower timer is also a limit ..I presume that would be your operating temperature limit which turns the fan on when the heat reaches operating temp...so, I would think that is where the problem is because if the blower doesn't come on at that time then the unit will shut off on High Heat which I think is the other fan control
Old 10-18-2012, 03:51 PM   #28
Thanks to everyone for the advice. I replaced the control fan timer (HQ1005229WA) today and I'm back up and running.
The Following User Says Thank You to robertsm For This Useful Post:
ben's plumbing (10-18-2012)
Old 10-18-2012, 04:13 PM   #29
Rewards Points: 610
Yaaaaayyyyy!!!!!!
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower motor in AC unit not coming on Big John Studd HVAC 10 10-05-2012 03:38 PM
Water heater blower needs re-wire kittf Plumbing 7 12-18-2010 10:44 PM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
