Tempstar 7000 Inducer Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 03:28 PM   #1
tempstar 7000 inducer noise
i have a 1990 tempstar 7000 furnace.I replaced the inducer blower in november when the fan was rubbing on the housing presumeably from being old.the new one worked great until last week when i started to notice a noise when it would shut down.it was a rumbleing noise right when it shut off but it didnt happen all the time. maybe a couple of times at night.when i pulled it off to have it warantied it seemed to have quite a bit of water in it.is that normal? it seems to be draining correctly out of the hose. anyway, i put the new blower on and its making the same noise.Any suggestions would be appreciated.
daddyfish2 is offline   Reply With Quote
Old 03-11-2013, 03:59 PM   #2
An old Tradesmen
Rewards Points: 7,376
Has the vent pipe sagged.
Old 03-11-2013, 04:02 PM   #3
Noise is likely water being 'slapped' by id fan wheel. Water should not be pooling in fan. Check and clear hoses, small ones and larger ones to drain. Do search in HVAC section for word 'paperclip'.
diyorpay is offline   Reply With Quote
Old 03-12-2013, 06:39 AM   #4
thanks for the response. the vent pipe appears to be straight. I am going to re level and hang the vent this evening as it is hung useing wire and not real stable. I will also check and clean the drain and trap. I will let everyone know how it goes. thanks again for the responses.
Old 03-12-2013, 04:03 PM   #5
An old Tradesmen
Vent pipe isn't suppose to be level. it should slant back toward the furnace.
Old 03-12-2013, 06:20 PM   #6
Rewards Points: 582
as suggested make sure exhaust pipe is slanted back to furnace about 1/4" per foot ...should solve your problem...
Old 03-12-2013, 07:43 PM   #7
Roofmaster
Rewards Points: 2,210
Yeah if his condensate lines are clear, which they probably aren't.
Draft Inducer Squealing Noise rbh123456789 HVAC 9 01-05-2012 12:37 PM
Carrier 58PAV Inducer Motor Noise mad116 HVAC 5 11-07-2011 01:37 AM
inducer blower motor Noise snwboarder45 HVAC 5 10-05-2009 10:39 AM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 02:10 PM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 08:38 AM
