-   -   tempstar 7000 inducer noise (http://www.diychatroom.com/f17/tempstar-7000-inducer-noise-174194/)
daddyfish2 03-11-2013 04:28 PM
i have a 1990 tempstar 7000 furnace.I replaced the inducer blower in november when the fan was rubbing on the housing presumeably from being old.the new one worked great until last week when i started to notice a noise when it would shut down.it was a rumbleing noise right when it shut off but it didnt happen all the time. maybe a couple of times at night.when i pulled it off to have it warantied it seemed to have quite a bit of water in it.is that normal? it seems to be draining correctly out of the hose. anyway, i put the new blower on and its making the same noise.Any suggestions would be appreciated.
beenthere 03-11-2013 04:59 PM
Has the vent pipe sagged.
diyorpay 03-11-2013 05:02 PM
Noise is likely water being 'slapped' by id fan wheel. Water should not be pooling in fan. Check and clear hoses, small ones and larger ones to drain. Do search in HVAC section for word 'paperclip'.
daddyfish2 03-12-2013 07:39 AM
thanks for the response. the vent pipe appears to be straight. I am going to re level and hang the vent this evening as it is hung useing wire and not real stable. I will also check and clean the drain and trap. I will let everyone know how it goes. thanks again for the responses.
beenthere 03-12-2013 05:03 PM
Vent pipe isn't suppose to be level. it should slant back toward the furnace.
ben's plumbing 03-12-2013 07:20 PM
as suggested make sure exhaust pipe is slanted back to furnace about 1/4" per foot ...should solve your problem...
jagans 03-12-2013 08:43 PM
Yeah if his condensate lines are clear, which they probably aren't.
