Tempstar 5000 Keep Reigniting - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 07:48 AM   #1
Tempstar 5000 keep reigniting
I have a Tempstar 5000 high efficiency furnace that is about 15 years old. Recently it started reigniting off & on at the end of each cycle. Usually at about 60 second intervals. This is causing the unit to run longer and I'm afraid it might cause the ignighter to fail.
I researched it down to possibly the flame sensor but I cleaned it with steel wool and nothing changed. Next I replaced the pressure switch but no change. I also cleaned the lower A-frame and change the filters monthly. I only use the cheap see-thru filters to get max airflow.
I wanted to squeeze one more winter out of the unit since our money is tight right now. Can anyone point me in the right direction or possibly offer more suggestions?
Thanks in advance
joe_2007 is offline   Reply With Quote
American Standard 5000 gas furnace PyrateJim HVAC 20 01-05-2011 01:48 AM
Tempstar AC Cooling ? raybo2223 HVAC 1 07-26-2009 09:20 AM
anyone familiar with Goodman and Tempstar pomelo HVAC 6 07-17-2009 05:59 AM
Tempstar issue with cooling cycle Teddy1731 HVAC 2 07-08-2008 10:15 AM
HEIL 5000 Furnace Problem moore70 HVAC 5 03-26-2006 07:59 PM
