Temporary Heat Using Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 04:30 PM   #1
Temporary heat using gas
I've got a 1901 two story Victorian that I'm starting to remodel and upgrade to modern things like new electrical, bathrooms, kitchen, etc. , but living here in an area of calif where the mornings are 30 and my home has an old gas floor furnace (which I do not trust), and is currently disconnected, I'm trying to find a temporary solution for heating. Electricity here is expensive and gas is cheap. These old lathe plaster walls seem to keep cold air in during winter and hot air in during the summer.
By spring I should be done with major work and will be putting in a high velocity mini duct system throughout the home.
butterkups is offline   Reply With Quote
Old 01-08-2013, 07:48 PM   #2
Rewards Points: 616
strict codes here for using gas furnaces as temporary heat.... we do it all the time for new housing..... you codes may be different.....
carmon is offline   Reply With Quote
Old 01-08-2013, 08:33 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
Hey....those old floor heaters are pretty tough and reliable....not a whole lot to go wrong. As long as the gas manifold is not cracked, it's clean in there and your exhaust flue pipe is intact.....crank her up. Mine was over 50 years old when I took it out....the only reason for removing it was because we had a new baby and the bedroom was cold....have to love forced air heating.,....
Old 01-08-2013, 09:35 PM   #4
Rewards Points: 952
Just crank up a kitchen range.
cleveman is offline   Reply With Quote
Old 01-08-2013, 09:56 PM   #5
Don't do that with a gas range, though. Or electric, if you're paying the bill. When I was younger, living in a basement suite, my landlord would turn my electric baseboard heat off, but would always blame it on his two-year-old (can two-year-olds reach a 5' high thermostat, with no chairs, tables or ladders around? It was in his foyer, not in my suite). Sick of his BS, I started to heat my suite with the electric range. When it got too hot, I'd just open a window. The electric meter spun like a top.
hvac benny is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
